Pony coils difficult to install
DarylJ
10-17-2005 19:08:10
The new coils for 70D pony motor distributor came today. I don't know if all replacement coils are this way, but the square hole in the center of each was slightly undersized. The coils did not slide on without some tapping on the ends of the center bar, using a rubber hammer. A small amount of insulation powder came along as the bar emerged through the coil. After repeating the same procedure with the second coil, I could see that the bar was slightly bent. It straightened easily by using a flat wooden stick to pry inbetween the coils. That I would need to resort to such crude measures is bothersome to say the least. Are all replacement coils this way? I haven't tried to start the pony yet tonight, but when I do so tomorrow after setting the new points, I'm not so sure whether these coils will be functioning or not. At this point, I'm thinking that I should have slightly filed the sharp edges off the bar edges before attempting to slide the coils on to prevent any coil wires from being scraped bare by the central bar being forced through. Prior to attempting to start the pony engine, are there any precautionary tests one should be making to learn whether or not the coils are damaged? Had I known in advance these problems were present, it may have been advisable to buy the complete distributor ready-to-install.....
Blksmok
10-18-2005 07:14:53
 Re: Pony coils difficult to install in reply to DarylJ, 10-17-2005 19:08:10
Daryl...this is a commom problem when replacing the pony coils. The center core bar is very soft and any pounding on the ends will mushroom them and create sharp edges. I normally avoid pounding on the bar and then before I reassemble everything I champher the ends of the bar, clean it thoroughly with a wire brush and wipe the bar down with a film of vaseline before sliding the new coils on the bar. I have seen where the sharp edges damaged the plastic inside the square hole, exposing the copper wire and causing a short. You should be able to tell if you have any damage when you turn the ignition switch on. You should see about a negative 5 to 10 amps on the ammeter, but it pegs out on the discharge side you need to pull it back apart to inspect the coils.
Two other common problems with replacing these coils is the proper insertion of the plug wires into the backside of the coils and running the aftermarket coils on something less than 6 volts (by pass the ignition switch resistor).
DarylJ
10-18-2005 16:05:27
 Re: Pony coils difficult to install in reply to Blksmok, 10-18-2005 07:14:53
Thanks for those tips. After setting the points to .020, I turned on the switch. The ammeter registers at -15 amps, not yet pegged. Next, I pulled a spark plug out and hooked a ground to it. Switch on, spun the starter, and no spark in the plug. Sounds like something is amiss, don't you think. What do you suggest? If I take an ohm meter reading of each coil, from positive to negative wires, what should the meter read? How much deviation would indicate a damaged coil? Thanks once again.
Blksmok
10-19-2005 05:17:59
 Re: Pony coils difficult to install in reply to DarylJ, 10-18-2005 16:05:27
Daryl...no spark so I'm assuming you tried to start the engine w/o success(??) Two quick things to try before you remove the coils for close inspection. 1) Dis-connect the hot wire coming from the switch to the terminal post on the side of the coil box and also dis-connect the two leads from the coils connected to the inside of the terminal post. Jumper those wires and see if you have spark. This terminal is prone to shorting and you may not be getting full juice to the coils. 2) Reconnect all the wires to this terminal and then jumper a wire from the starter hot post directly to the terminal and then check for spark. This eliminates poor contacts in the switch and the resistor on the back of the switch. If after these two tests you still don't have spark, pull the coils off and remove them from the center bar. Inspect inside the square hole to see if any copper wires are visable. If so, time for new coils.
DarylJ
10-20-2005 12:21:34
 Got it going, it was the terminal post..... in reply to Blksmok, 10-19-2005 05:17:59
Blksmok, thanks for suggesting the terminal post. It was corroded, which I discovered after bypassing it with the jumper. Cleaned it up, and the pony fired right up. Put the cover back on and it wouldn't start..... so pulled it off and discovered another little item to be careful of.....the clips on the ends of the wires which hook up to the terminal were touching the cover, and shorting out to ground. Carefully straightened them, being careful that they not touch the case, put it together, and it was fine again. Tight quarters inside there, so one has to be careful where the wires/clips are resting.
DarylJ
10-19-2005 08:54:46
 Re: Pony coils difficult to install in reply to Blksmok, 10-19-2005 05:17:59
I will try your suggestions. Thanks. Does the 15 volt discharge reading on the ammeter sound excessive?
Blksmok
10-19-2005 10:43:50
 Re: Pony coils difficult to install in reply to DarylJ, 10-19-2005 08:54:46
Daryl...a 15 amp discharge is a little higher than normal. If you had a dead short it would peg the ammeter to the left. Does the discharge level vary as you crank the pony motor or is it constant (should change as points open and close).
F-I-T
10-19-2005 12:47:12
 Re: Pony coils difficult to install in reply to Blksmok, 10-19-2005 10:43:50
Do you have juice at the points? Remove the distributor cover and manually push one of the sets of points apart if they are closed. If you see spark, the primary side is getting power.
Next, put a piece of paper between the points and see if the current goes away. If it does, you have a short on the primary side of one or another coil.
Next, unhook first one and then the other coil power input wire and see if you still have a high current draw.
Or, do the reverse, unhook all wires and start adding them back on one at a time and see when you get the high current draw.
Frank
DarylJ
10-19-2005 19:21:23
 Re: Pony coils difficult to install in reply to F-I-T, 10-19-2005 12:47:12
If I understand correctly, if one of the coils causes a heavy draw of current, then that coil is defective? If both (individually) cause a heavy draw, then both are defective? Didn't get to check these tips out tonight, but will do so tomorrow, then report back. Thanks guys.
F-I-T
10-20-2005 11:46:50
 Re: Pony coils difficult to install in reply to DarylJ, 10-19-2005 19:21:23
Yes, I would say both would be "suspect".
Duane Larson
10-17-2005 19:46:35
DarylJ,
I wouldn't worry about it - most are a snug fit so they don't move around on the pole pieces. It is not unusual to scrape off some of the insulation while installing them. There is a variation in my experience, which involves the laminated core piece and any rust which may be separating the laminations. I haven't used any of the cheaper imported coils so can't comment on the fit with those.
I would go ahead and finish the job, and do the ultimate test - does the pony start?
