Mike: I said that if you go to a dealer and buy a replacement bolt today, it will be a grade 8 because the old "High Strength" fastener type is now obsolete. I also said that I trust Albert of Renaissance Tractor's advice who, in his seminars, highly recommends Grade 8, fine thread fasteners, with hardened washers under tall nuts, torqued to the spec for grade 8. I use the torque for the coarse thread, even though you can get a bit more on the fine thread since it has a greater cross-sectional area since the threads are not as deep. I also said that you can crack any casting you want, including a flywheel if you use a big enough pipe with no regard to measured torque, so to say that 370 lbs, or even 475 lbs will crack an ear and 265 will not is a guess, and only a guess. It is apparane that the engineers wanted to get as much pinch as possible, or else they would have and could have specified a torque reading that even below that of the maximum of a grade 5 or high strength bolt, but thet chose to torque it to the maximum that the fastener could stand. That sounds to me like they were more worried about the strength of the bolt than the strength of the flywheel casting. It is my opinion, and only my opinion, that the original torque specification was not based on the force that the flywheel "ears" could stand, but on the maximum torque of the "high strength" fasteners of the day. If John Deere engineers had had Grade 8 available to them, I believe they would have specified grade 8 and not grade 5. and increased the specification to 370, but I admit that this is an assumption on my part. I also said that of the flywheels I have seen cracked, only two that I could see were the result of excessive fastener torque breaking off the ears, but generally other problems such as stress risers from burrs and nicks on the crank splines or on the internal broached splines opf the flywheel caused a stress point that gave way. Many flywheels have cracked over the years, but not just on diesels, and not just around the ears. In the two cases where an ear was broken off on a diesel flywheel, one of those had grade 3 bolts installed. The torque to break the remaining bolt loose was beyond the measurement of my 400 ft-lb wrench, which I had set up with a two foot amplifier, so the torque was probably in excess of 700 lbs. The grade 3 bolt that remained was well stretched. So, I did say that I like to use grade 8 bolts, torqued to spec for the reasons stated above. So it sounds like we disagree. Frank
