60 PTO cover and shaft seal leak
Fred from MO
10-02-2005 05:25:46
When I run my PTO, 90 wt oil is bubbling up between the front cover of the PTO and the rest of the main housing. It is also leaking around my PTO shaft/seal. Looking at my IT manual it appears to take this cover off, all the clutches come out. I was hoping to unbolt the cover, replace the gasket as well as the PTO shaft seal. Anyone have any pointers on stopping these leaks?-Thanks
F-I-T
10-02-2005 06:24:31
 Re: 60 PTO cover and shaft seal leak in reply to Fred from MO, 10-02-2005 05:25:46
third party image
Fred:
You should be able to just remove the three cap screws and fish out the seal, replace it and the gasket and be on your way.
My concern is that you said it is leaking 90 wt. oil. There should be engine oil of the same weight used in the motor for that time of year. 90 weight gear lube is a sure way to ruin those expensive pto clutch packs.
Frank
Fred from MO
10-02-2005 06:54:42
 Re: 60 PTO cover and shaft seal leak in reply to F-I-T, 10-02-2005 06:24:31
Thanks Frank!
Come to think of it. I can't remember if it was 90wt or not. IT manual says use 10Wt. Do you think Regular 30 Wt will work or should I use general hydraulic fluid?
Also from your diagram It looks as though my main leak is from #12 gasket being bad. Have you ever replaced one of those, and do all the guts of the PTO come out with the front cover.
Thanks
F-I-T
10-02-2005 08:09:33
 Re: 60 PTO cover and shaft seal leak in reply to Fred from MO, 10-02-2005 06:54:42
~~Come to think of it. I can't remember if it was 90wt or not. IT manual says use 10Wt. Do you think Regular 30 Wt will work or should I use general hydraulic fluid?
I use the oil that I use in the engine for that time of year. Down here I use Rotella in all places where they call out engine oil. The 10 wt. was called out because they never wanted it to get stiff and turn the shaft in cold weather when it was disengaged, but whenever we put a load on it, even as light as an auger, it warmed that oil up pretty fast.
~~Also from your diagram It looks as though my main leak is from #12 gasket being bad. Have you ever replaced one of those, and do all the guts of the PTO come out with the front cover.
I think not, but my book is packed away so I'll have to find it and look it over. There is a snap ring on the aft end of the power shaft clutch shaft, so I'm wondering if you can remove that, then convince the bearing to slide off, or maybe the bearing just slides out of its bore (been a l-o-n-g- time since I had one apart), which I now think is more likely the case, leaving the shaft/clutch assembly in place while you remove the cover. I would also think leaving the clutch pack in the engaged position would be wise.
If someone doesn't cover this with you, I'll try to check back in later.
Frank
Fred from MO
10-02-2005 08:52:40
 Re: 60 PTO cover and shaft seal leak in reply to F-I-T, 10-02-2005 08:09:33
Frank, Just had a thought, since it is bubbling out of the top between the front cover of the PTO and the main housing of the PTO, and it appears to be 90 wt. I wonder if this is a case of the pump seal going bad and filling the PTO case with 90wt oil? I have read a lot about that in this forum. What do you think?
John Van Valkenburgh
10-03-2005 16:42:13
 Re: 60 PTO cover and shaft seal leak in reply to Fred from MO, 10-02-2005 08:52:40
Fred,
I went through this on my model 50 about a year ago. There are two areas where oil can leak. First the rockshaft uses 30 wt. motor oil. This oil sometimes leaks into the transmission. There is a "Rockshaft Cylinder Gasket" which sometimes goes bad causing this. Another problem is when you are using the rockshaft to hold up an implement and it begins to sink down after a few seconds. There is a large "O" ring on a piston that rides inside the Rockshaft Cylinder that will cause this.
Finally these old John Deeres are known for leaking transmission oil into the PTO housing. Transmission oil is Gear oil (something like 90 wt) and the PTO uses motor oil (something like 10 wt). Gear oil will eventually ruin the PTO Clutch disks. In this case there is a little seal on the PTO Oil pump that will leak.
I mention all this because replacing the PTO Pump seal and replacing the Rockshaft Cylinder Gasket both require that you remove the Rockshaft housing. Its not complicated but its heavy, dirty work and you may want to take care of both items at the same time.
I posted a note about this with some pictures I took that you may find useful. I'll post the link here.
Best of luck,
John
1953 Model 50
Fred from MO
10-04-2005 02:21:40
 Re: 60 PTO cover and shaft seal leak in reply to John Van Valkenburgh, 10-03-2005 16:42:13
Thanks for the link to the picture. This was especially helpful. I was not aware that the other seal was in there. I am pretty positive it is the PTO pump seal, but I think it would be a good idea to change the other one as well.
F-I-T
10-02-2005 09:06:08
Yes, that is probably what is going on. Drain that unit and inspect the oil It's not hard to tell the difference between 10 wt. and gear lube. If that is the case, you might want to repair that right away if you intend on using the PTO. I did the last one on my 70D and to remove the back cover, install the seal, and replce took one Saturday morning.
Fred from MO
10-02-2005 09:53:09
 Re: 60 PTO cover and shaft seal leak in reply to F-I-T, 10-02-2005 09:06:08
The back cover just unbolts from the axle housing.? Rockshafts and all go too correct?
F-I-T
10-02-2005 11:44:07
 Re: 60 PTO cover and shaft seal leak in reply to Fred from MO, 10-02-2005 09:53:09
Yes. It's heavy and generally dirty. An engine hoist helps a lot.
Getting the hydraulic lines loose is generally the biggest pain. Use some propane torch heat on those to liquify the goo and they generally come out ok. Be carful with them as replacements for certain models are not available.
Frank
fred from MO
10-02-2005 19:21:32
 Re: 60 PTO cover and shaft seal leak in reply to F-I-T, 10-02-2005 11:44:07
Are you talking about the metal hydraulic lines? If so what keeps them in the casting? Do you just pull? or is there a clip?
F-I-T
10-03-2005 05:02:08
 Re: 60 PTO cover and shaft seal leak in reply to fred from MO, 10-02-2005 19:21:32
third party image
Fred:
Do you have a parts book? If you don't, now is a great time to get one as you could easily ruin a part that you cannot replace when you get into a repair like this. Until then, the lines are held in place using a bolted on top plate, and the tube ends are fitted with an o-ring, but after years of sitting in one place there will be a ton of varnish holding the tubes in the bores.
Frank
Fred from MO
10-04-2005 02:11:50
 Re: 60 PTO cover and shaft seal leak in reply to F-I-T, 10-03-2005 05:02:08
Frank, I do not have a parts book. I think I will get one. Is the parts book how you are able to get such detail schematic drawings you have been posting? These are a great help and I appreciate all the advice you have provided. Heck I got my loader working with the help of everyone on this forum. Did you buy the CD rom version of the parts book? Does mother deere sell these?
Thanks
F-I-T
10-02-2005 06:24:24
third party image
Fred:
Frank
