I think I can offer an opinion here, based upon my recent experiences with my model 60. My clutch would stay engaged, but wouldn't hold an adjustment, and was often hard to disengage.I posted similar question(s) to yours on this forum. I ended up pulling the clutch pulley drum completely off of the tractor to inspect the internals (dogs, toggles, pins, and alignment pin). What I found was the alignment pin hole was severely oblonged, almost oval shaped. I used a 5 ton puller, an impact wrench, and the torch to remove the large gear on the interior side of the pulley. This gear must be removed in order to access the collar where the alignment pin is located. I ordered a new alignment pin from John Deere. It cost $4.84. The collar costs over $300. So -- I decided I would do some work on it. I marked the collar so that I could see where the alignment pin should ride. You'll know it is correct because the toggles will appear at a 90 degree angle. You can move the collar with your hands, to see how the dogs ride over the center to engage your clutch. You'll also likely see from the wear in the alignment pin, why they don't stay over the center. Once you have the gear off you can pull the collar off easily with your hands. I had a friend TIG weld the hole in the ear of the collar, then we used a drill press and step drilled the hole until it was the correct diameter. The whole process required more grinding and drilling than it did welding. The worse part of the whole process was pulling the gear -- it has a keyhole -- you'll need to scrape off the years of grime to find it. The old alignment pin is easy to remove. Just attach vise grips to it and heat the area around the base of the pin with the torch. It will come out quickly and easily. Once you have throughly cleaned and repaired everything, repack the roller bearing that is inside the pulley. The only lubrication this bearing gets is what you give it at this point, so take your time here. When you reinstall the dogs and toggles, lubricate them with good wheel bearing grease. The large gear will likely have to be pressed on using a shop press. With the press and some lightweight oil we pushed it on in no time flat. Polish the interior of your clutch drum with some scotch brite and then reinstall the clutch linings per the manual. Make sure your "V" notch on the balanced clutch driver matches the notch on the crankshaft. I did this and my clutch works as good as new. It took two adjustments to get everything pulled up tight, but it works great, and there is no variance in its engagement. Best regards, Tom
