JD 630 Clutch disengaging
Big Jon
09-19-2005 18:37:02
I have adjusted the clutch the best I know how. It pulls fine but I have to keep my hand on the lever.
Bruce L
09-19-2005 20:26:31
 Re: JD 630 Clutch disengaging in reply to Big Jon, 09-19-2005 18:37:02
You might have worn clutch operating parts which will require disassembly for exact diagnosis. It sounds like the clutch isn't snapping over center. Worn dogs/toggles and the pin that goes through the dogs can cause this. You will have to take the whole pulley assembly off to find out for sure. If the hole where the pin goes through is elongated, I have heard it is possible to weld them up and re-drill. I haven't done that myself but I have one I am going to try it on. While you have it appart, it would be a good time to service the bearing.
DP
09-19-2005 20:09:18
Many things can effect the clutch operation. First of all does it have a distinct over center feel? The dogs, toggles, and the alingment pin and ear are probably the problem if it is not snapping over center. I had a problem with my 630 back in the early 80's while picking corn. Removed the clutch and had everything rebuilt one rainy day. (This involved removing the picker). I was very disturbed when I went back to picking, only to find that after about 200 to 300 feet the clutch would pop out. I finished picking with my foot laying against the clutch lever. It took very little effort to hold it in. After the picker was removed I once again started checking it out. I found a break in the first reduction housing between where the clutch forks bolt in and the main case. It would allow it to give and allow the clutch to pop out, and would spring shut so it could not be detected. Kind of a strange deal, but I suppose it could happed twice. Good luck and keep us posted as to what you find. Don
Tom in Montoursville
09-20-2005 13:35:01
 Alignment pin in reply to DP, 09-19-2005 20:09:18
I think I can offer an opinion here, based upon my recent experiences with my model 60. My clutch would stay engaged, but wouldn't hold an adjustment, and was often hard to disengage.
I posted similar question(s) to yours on this forum. I ended up pulling the clutch pulley drum completely off of the tractor to inspect the internals (dogs, toggles, pins, and alignment pin). What I found was the alignment pin hole was severely oblonged, almost oval shaped.
I used a 5 ton puller, an impact wrench, and the torch to remove the large gear on the interior side of the pulley. This gear must be removed in order to access the collar where the alignment pin is located.
I ordered a new alignment pin from John Deere. It cost $4.84. The collar costs over $300. So -- I decided I would do some work on it. I marked the collar so that I could see where the alignment pin should ride. You'll know it is correct because the toggles will appear at a 90 degree angle. You can move the collar with your hands, to see how the dogs ride over the center to engage your clutch. You'll also likely see from the wear in the alignment pin, why they don't stay over the center.
Once you have the gear off you can pull the collar off easily with your hands. I had a friend TIG weld the hole in the ear of the collar, then we used a drill press and step drilled the hole until it was the correct diameter. The whole process required more grinding and drilling than it did welding.
The worse part of the whole process was pulling the gear -- it has a keyhole -- you'll need to scrape off the years of grime to find it. The old alignment pin is easy to remove. Just attach vise grips to it and heat the area around the base of the pin with the torch. It will come out quickly and easily.
Once you have throughly cleaned and repaired everything, repack the roller bearing that is inside the pulley. The only lubrication this bearing gets is what you give it at this point, so take your time here. When you reinstall the dogs and toggles, lubricate them with good wheel bearing grease. The large gear will likely have to be pressed on using a shop press. With the press and some lightweight oil we pushed it on in no time flat.
Polish the interior of your clutch drum with some scotch brite and then reinstall the clutch linings per the manual. Make sure your "V" notch on the balanced clutch driver matches the notch on the crankshaft.
I did this and my clutch works as good as new. It took two adjustments to get everything pulled up tight, but it works great, and there is no variance in its engagement.
Best regards,
Tom
