If it has the PowerTrol, yes.
Steve from MO -
09-08-2005 06:32:40
The PowerTrol was probably an option although I haven't seen a late B without. It includes a rockshaft for a cultivator lift that operates from the hydraulics with an internal cylinder. You hook a 3-point setup to the rockshaft.
edward1
09-08-2005 06:44:17
 Re: If it has the PowerTrol, yes. in reply to Steve from MO - dangit!, 09-08-2005 06:32:40
So, what kind of lift capacity would it have at the drawbar?
grapefarmer
09-08-2005 14:20:33
 Re: If it has the PowerTrol, yes. in reply to edward1, 09-08-2005 06:44:17
My 1954 JD 50 (same a the B) with a homebrew 3 point using what looks like arms from a ford 9n can lift about 1000 pounds. Front get light though.
-Dave
Mike M
09-08-2005 07:20:27
I don't know the lift capacity in weight but I have used a 7 1/2 foot Ford flail mower on mine before. You are going to need to make a weight bracket for the front to hold it down.A model 50 had enough extra built in weight for the 3pt.
