A quick 1950 B question
Edward1
09-08-2005 06:28:26
Ok, no beating me up to much here please:), but I have only owned red and orange tractors in the past. I have the opportunity to look at and purchase a decent 1950 B. Do all the B"s have the capability of having the aftermarket 3pt installed to the tractor without having to add a cylinder. I can"t find any decent phots of the back of a 1950 B. ANybody know where I might locate some pictures before I drive out to see the one thats for sale?
Leroy
09-08-2005 18:59:38
 Re: A quick 1950 B question in reply to Edward1, 09-08-2005 06:28:26
A late B could be gotten with out any hydrolics or either just the power lift that is only up or down with most likely a foot pedal control and no remote capabilities or the power troll, hand lever, that has the ability to raise or lower to any position then stop and also provisions for a remote cylinder. Either with power lift or power troll can be used with a 3 point hitch, power lift would need gage wheels, power troll not. The B will not lift as much as the 50 as the hydrolics were not made as strong and the 50 has approx. 2-300 more PSI than the B. Now if made with no hydrolic (RARE) it would not have a rockshaft and could not be used with a 3 point
CLW
09-08-2005 12:02:36
Link
CLW
MITCHP
09-08-2005 10:49:22
go to www.tonystractors.com and check out the 3point hitches there, good hitches that hook up in no time. it'll show you how it hooks to the tractor
Dave 2N
09-08-2005 10:33:28
I have a 48 A with a Saginaw 3 pt. kit. This kit will work on a B, A or G with rockshaft. I hg with a 5' rotary cutter. Wouldn't be afraid to put the 3 pt. kit on the B.
Steve from MO - dangit!
09-08-2005 06:32:40
 If it has the PowerTrol, yes. in reply to Edward1, 09-08-2005 06:28:26
The PowerTrol was probably an option although I haven't seen a late B without. It includes a rockshaft for a cultivator lift that operates from the hydraulics with an internal cylinder. You hook a 3-point setup to the rockshaft.
edward1
09-08-2005 06:44:17
 Re: If it has the PowerTrol, yes. in reply to Steve from MO - dangit!, 09-08-2005 06:32:40
So, what kind of lift capacity would it have at the drawbar?
grapefarmer
09-08-2005 14:20:33
 Re: If it has the PowerTrol, yes. in reply to edward1, 09-08-2005 06:44:17
My 1954 JD 50 (same a the B) with a homebrew 3 point using what looks like arms from a ford 9n can lift about 1000 pounds. Front get light though.
-Dave
Mike M
09-08-2005 07:20:27
I don't know the lift capacity in weight but I have used a 7 1/2 foot Ford flail mower on mine before. You are going to need to make a weight bracket for the front to hold it down.A model 50 had enough extra built in weight for the 3pt.
