Intercooler vs HP (bd????)
Tx Jim
09-04-2005 14:10:35
buickanddeere,could you explain how lack of intercooler limits increasing horsepower(your quote"non intercooled engines can't be cranked as high")? I know that an intercooler cools air so that more can be drawn into cylinders! But if one wants to spend enough $$$'s HP can be increased without the aid of an intercooler. Tx Jim
720Deere
09-04-2005 14:49:18
 Re: Intercooler vs HP (bd????) in reply to Tx Jim, 09-04-2005 14:10:35
He is speaking of reliable HP. You can push quite a bit of extra ponies out of a diesel with a cloud of smoke, but not for long!
buickanddeere
09-04-2005 22:59:59
 Re: Intercooler vs HP (bd????) in reply to 720Deere, 09-04-2005 14:49:18
Increased charge density with lower temperatures at the same pressure. As much or more delta T in the combustion chamber in order to build working pressure with the cooler intake air. Yet max combustion chamber/exhaust temps are lower = an engine that doesn't melt. 720Deere if an intercooler didn't have some advantage(s). Why do manufactures find the extra money, space and cooling capacity for an intercooler?
720Deere
09-05-2005 04:49:55
 Re: Intercooler vs HP (bd????) in reply to buickanddeere, 09-04-2005 22:59:59
I don't see anything in any of my posts that said anything against an intercooler. If you buy a Banks kit for a pickup, one of the first things that they do is either add an intercooler or upgrade the one that is there.
Super stock pullers make tons of hp by raising the fuel and boost by more than ten times what it was meant to be run at. We have all seen the pictures of them blowing apart. Nothing is free. As my father always says, "You gotta pay to play!".
buickanddeere
09-05-2005 08:14:51
 Re: Intercooler vs HP (bd????) in reply to 720Deere, 09-05-2005 04:49:55
The super stock tractors get the combustion chamber pressure up while controlling combustion chamber temps a few ways. An over rich mixture burns cooler than mixture at it's ideal to slightly lean ratio. Fuel cooled like radial aircraft engines during take off. The compression ratio has been lowered. Water injection absorbs heat as the water flashes to steam. Some experiment with ice water, CO2 etc intercoolers. Weight,complexity, size and flow restriction become an issue.
