HEY G-MAN POWER CHIP?
TIMAR
09-03-2005 11:33:37
Ever seen any put a chip in a new 20 series John Deere 8.1L? If so, see any problems?
buickanddeere
09-03-2005 17:06:46
 Re: HEY G-MAN POWER CHIP? in reply to TIMAR, 09-03-2005 11:33:37
More fuel, more heat, more pressure thus shorter engine life. Shorter drivetrain life due to higher pressure on gear teeth. More twist on the shafts causing more distortion. And more slippage/wear/heat on the clutch packs when they slip during shifts. Overfueling will also soot up the ring lands, ports and turbine blades. Unburned fuel will wash lube oil off the cylinder walls. Fuel efficiency will drop as lbs of fuel per HP/hr increases.
720Deere
09-03-2005 17:48:44
 Re: HEY G-MAN POWER CHIP? in reply to buickanddeere, 09-03-2005 17:06:46
Your record sure is broken! Show some documentation for the results that you speak about so much. I ran a 4840 for years that turned over 220 hp! That very same tractor made it to just over 8,000 hours before they had minor transmission problems. Over 10,000 hrs before major overhaul. I know for a fact that the hp that tractor made was abused every day. They worked the guts out of it and it still lasted better than average, in fact it's still going strong at close to 13,000 hrs! 220 hp is nearly 25% more than stock for a 4840. Most guys that ask these questions aren't looking for near that much just 10% to 15%.
Many people have been using chips in the 8.1L motors with great success. People who are educated on the more popular chips will tell you that they are safe and effective. The chip monitors temps and will go back to default settings if things get out of shape. Our local Deere dealer actually installs them at the customer's request. They have several 8?20 tractors out there that do heavy work and rack up close to 1000 hrs per year. It's been going on for several years and I have yet to hear of any problems. Hopefully G-Man will chime in. I'm interested to hear what he has to say.
Mike M
09-03-2005 19:50:24
 Re: HEY G-MAN POWER CHIP? in reply to 720Deere, 09-03-2005 17:48:44
I have always wondered about theses chips and add ons with all the wonderfull claims made. If it was really that simple why didn't they just build them that way from the start ? Afterall everyone seems to want more more more ? I think some kind of trade off is to be expected.
720Deere
09-04-2005 05:33:00
 Re: HEY G-MAN POWER CHIP? in reply to Mike M, 09-03-2005 19:50:24
John Deere uses the 8.1L engine for hp ratings from less than 130 to more than 200 hp. With electronically controlled engines the computer is the difference in the hp. Caterpillar is the same with their engines. Many times if you buy a 550 hp CAT engine, it will come through at 435 to 450 hp and after a few miles you take it back to the dealer and they reprogram the computer to the desired hp.
If you have a 7710 and chip it to 200 hp, that engine is not doing anything that it was not designed to do. The only area that can be questioned is the drive train. Unless the tractor is over-ballasted along with the increased hp, I seriously doubt that there will be any problems. Remember the chip is not "grossly overfueling" the engine, it is simply boosting it to it's engineered capabilities.
buickanddeere
09-04-2005 11:30:01
 Re: HEY G-MAN POWER CHIP? in reply to 720Deere, 09-04-2005 05:33:00
Some engines are intercooled along with the turbo and others are not. The non intercooled engines cannot be cranked as high. Depending on the factory HP, the turbo maybe sized differently with the same displacement engine. I should clarify there is a difference between max factory rated HP for that engine combination. And then there is the "turning up" beyond factory rated. I am also thinking of medium frame 4440�s turned way up trying to match a large frame 4640 or 4840. True within the same tractor frame size, should they be equipped with the same size dia rear axles. There should not be any particular problems. For example on the wee tractors such as the 5105 and 5205. The only difference between the two tractors is the price, decals on the hood and injection pump delivery.
Tx Jim
09-04-2005 14:10:35
 Intercooler vs HP (bd????) in reply to buickanddeere, 09-04-2005 11:30:01
buickanddeere,could you explain how lack of intercooler limits increasing horsepower(your quote"non intercooled engines can't be cranked as high")? I know that an intercooler cools air so that more can be drawn into cylinders! But if one wants to spend enough $$$'s HP can be increased without the aid of an intercooler. Tx Jim
720Deere
09-04-2005 14:49:18
 Re: Intercooler vs HP (bd????) in reply to Tx Jim, 09-04-2005 14:10:35
He is speaking of reliable HP. You can push quite a bit of extra ponies out of a diesel with a cloud of smoke, but not for long!
buickanddeere
09-04-2005 22:59:59
 Re: Intercooler vs HP (bd????) in reply to 720Deere, 09-04-2005 14:49:18
Increased charge density with lower temperatures at the same pressure. As much or more delta T in the combustion chamber in order to build working pressure with the cooler intake air. Yet max combustion chamber/exhaust temps are lower = an engine that doesn't melt. 720Deere if an intercooler didn't have some advantage(s). Why do manufactures find the extra money, space and cooling capacity for an intercooler?
720Deere
09-05-2005 04:49:55
 Re: Intercooler vs HP (bd????) in reply to buickanddeere, 09-04-2005 22:59:59
I don't see anything in any of my posts that said anything against an intercooler. If you buy a Banks kit for a pickup, one of the first things that they do is either add an intercooler or upgrade the one that is there.
Super stock pullers make tons of hp by raising the fuel and boost by more than ten times what it was meant to be run at. We have all seen the pictures of them blowing apart. Nothing is free. As my father always says, "You gotta pay to play!".
buickanddeere
09-05-2005 08:14:51
 Re: Intercooler vs HP (bd????) in reply to 720Deere, 09-05-2005 04:49:55
The super stock tractors get the combustion chamber pressure up while controlling combustion chamber temps a few ways. An over rich mixture burns cooler than mixture at it's ideal to slightly lean ratio. Fuel cooled like radial aircraft engines during take off. The compression ratio has been lowered. Water injection absorbs heat as the water flashes to steam. Some experiment with ice water, CO2 etc intercoolers. Weight,complexity, size and flow restriction become an issue.
