Fabricating anti-sway unit
Tom in Montours
08-07-2005 06:03:04
Jim,
I've been thinking about fabricating something, and have a couple of designs in my head. The biggest thing I lack is time. Can you, or anyone else, send a picture, or describe how JD solved this issue?
Tom
F-I-T
08-07-2005 06:33:35
 Re: Fabricating anti-sway unit in reply to Tom in Montoursville, 08-07-2005 06:03:04
third party image
Here is a picture of a stabilizer bar. Sorry, it's not the best, but I think you can get the idea that it would pin to the lugs on one arm, then pin to a lug on the other arm. I do not know the dimensions, but if you are fabricating it, it should not ne too tough to derive.
JDVan will know the dim's.
Frank
Mike M
08-09-2005 09:25:06
 Re: Fabricating anti-sway unit in reply to F-I-T, 08-07-2005 06:33:35
Can't those get in the way of the pto shaft ??
I just hooked my top link up by removeing the original cross piece and then place the ends of the arms on the OUTSIDE of the upright using a long 3/4" bolt go through the holes and leave the center part where you normally hook open. This makes your implements level and also takes out the sway.
08-07-2005 17:05:52
Frank,
Do you have a larger picture of that triangle? That looks right up my alley.
I will also call the number provided and in a reply I'll let you all know the cost.
Anyone else want to opine?
Will the so called "knock blocks" from the later number series fit my old reliable 60?
Tom
F-I-T
08-08-2005 02:58:19
 Re: Fabricating anti-sway unit in reply to Tom in Montoursville, 08-07-2005 17:05:52
SOrry. No better picture. I'll try to get one and post it here.
I do not think the sway blocks from a 620 will fit as the lift arms and the drawbar box assembly are different. I believe you would have to add many different parts to make it satisfactory.
Frank
