Knock blocks for 3pt hitch - JD 60
Tom in Montours
08-06-2005 09:42:07
Can anyone help me with where I can locate an anti-sway kit for my 3pt on my 60? I was told they are called "knock blocks."
My 84 inch mower wanders all over behind my tractor.
Thanks in advance
Tom
MSM
08-06-2005 13:38:28
 Re: Knock blocks for 3pt hitch - JD 60 in reply to Tom in Montoursville, 08-06-2005 09:42:07
If it has an original 800 or 801 hitch,it uses sway chains. These go from the lower links to the drawbar. If it has an aftermarket hitch,it should either use sway chains,or adjustible links depending on the manufacturer. The later Deere models used sway blocks that bolted to the "elephant ears" which were part of the factory 3pt.
08-06-2005 19:37:20
 Sway chains for 3 point in reply to MSM, 08-06-2005 13:38:28
I have an original three point, although I don't know what model it is. Where can I find the sway chain kit?
I really need it. The 84 inch mower really gets to swinging and I'm afraid I'm going to break something.
Tom
Tx Jim
08-07-2005 03:51:08
 Re: Sway chains for 3 point in reply to Tom in Montoursville, 08-06-2005 19:37:20
Tom,I think that factory sway chains for 800 series 3 pt will not totally stop sway.Why not build a triangle that fastens to both draft links similiar to factory made piece? Tx Jim
08-07-2005 06:03:04
 Fabricating anti-sway unit in reply to Tx Jim, 08-07-2005 03:51:08
Jim,
I've been thinking about fabricating something, and have a couple of designs in my head. The biggest thing I lack is time. Can you, or anyone else, send a picture, or describe how JD solved this issue?
Tom
F-I-T
08-07-2005 06:33:35
 Re: Fabricating anti-sway unit in reply to Tom in Montoursville, 08-07-2005 06:03:04
third party image
Here is a picture of a stabilizer bar. Sorry, it's not the best, but I think you can get the idea that it would pin to the lugs on one arm, then pin to a lug on the other arm. I do not know the dimensions, but if you are fabricating it, it should not ne too tough to derive.
JDVan will know the dim's.
Frank
Mike M
08-09-2005 09:25:06
 Re: Fabricating anti-sway unit in reply to F-I-T, 08-07-2005 06:33:35
Can't those get in the way of the pto shaft ??
I just hooked my top link up by removeing the original cross piece and then place the ends of the arms on the OUTSIDE of the upright using a long 3/4" bolt go through the holes and leave the center part where you normally hook open. This makes your implements level and also takes out the sway.
08-07-2005 17:05:52
Frank,
Do you have a larger picture of that triangle? That looks right up my alley.
I will also call the number provided and in a reply I'll let you all know the cost.
Anyone else want to opine?
Will the so called "knock blocks" from the later number series fit my old reliable 60?
Tom
F-I-T
08-08-2005 02:58:19
 Re: Fabricating anti-sway unit in reply to Tom in Montoursville, 08-07-2005 17:05:52
SOrry. No better picture. I'll try to get one and post it here.
I do not think the sway blocks from a 620 will fit as the lift arms and the drawbar box assembly are different. I believe you would have to add many different parts to make it satisfactory.
Frank
