JD #5 sickle mower flywheel removal-how?
Randy G.
06-19-2005 10:15:39
I just got a #5 7' sickle mower and the lower seal on the gearbox leaks badly.(behind the pittman shaft)How do I go about replacing the seal? The pittman is already off. What are my next steps? How IS the flywheel removed? Does Deere still sell the seals? Any help is welcome. Thanks, Randy
Bob
06-19-2005 10:26:52
 Re: JD #5 sickle mower flywheel removal-how? in reply to Randy G., 06-19-2005 10:15:39
The Z6573H seal is still a good number @ about $6.50.
Here's a link to a previous thread on flywheel removal:
55 50
06-20-2005 22:58:46
 Re: JD #5 sickle mower flywheel removal-how? in reply to Bob, 06-19-2005 10:26:52
After reading the entries in the referenced link, the obvious question is "Why would you need to pull the flywheel off the shaft, when all you want to do is replace the seal and you have taken the gear off the rear end of the shaft and pulled the flywheel (with shaft) out the front?
