JD No. 5 Power Mower
TC45
03-14-2005 23:49:28
Can anyone tell me how to get the crank wheel off the end of the shaft coming out of the chain drive housing? The shaft does have a keyway but no set screws. I tried hammering around the edge but it"s not budging. Do you have to heat it up?
Tim
DRL
03-15-2005 19:11:40
 Re: JD No. 5 Power Mower in reply to TC45, 03-14-2005 23:49:28
The flywheel is held on by a wedge shaped key. You need to get the flywheel to move in towards the gearbox to expose the key and relieve the pressure. Some will drill and tap a hole in the key in order to put a screw in it. They then get hold of the screw and tap the key out. Sometimes heat is required, but if it is like mine, there is enough gear grease on it, there isn't much danger of rust. After you get the key extracted, the flywheel should pull off without much trouble. You might get it off by just using a large puller, but you will probably need to get a new key afterward.
Hayfarmer
03-15-2005 07:53:27
Seems like that flywheel comes loose when you don't want it to and won't come off when you do. I took one off last year but believe I just rapped on the edges with a large hammer. It is pretty substancial and should hold up unless you get really wild. If you can rap on one side, turn and rap on the other and take it a little at a time it should come loose. Also if you can work it out a bit then push it back in leaving key sticking out it should come out. I believe it is a tapered key. The rear sprocket does turn off but not easily think mine required heat after I got it out.
Bob
03-15-2005 07:21:25
That crank wheel is a TIGHT press-fit to the shaft, and HAS to be to stay on., with all the pounding it takes from driving the sickle.
You need a big puller, or better yet, a press to get it off.
If I remember right, the sprocket on the other end of the shaft unscrews, and then you can remove the shaft and wheel as a unit, and put them in a press to remove the wheel.
NOT press fit
03-17-2005 19:45:16
 Re: JD No. 5 Power Mower in reply to Bob, 03-15-2005 07:21:25
Bob, that flywheel is only held on by the tapered key. After the key is out, the flywheel is loose on the shaft.
Larry in WNY
03-16-2005 09:33:29
If my memory is right, the rear sprocket has reverse threads. Tap it with a brass hammer or soft punch and it should come off and then you can use a press to get the flywheel off the other end.
