Positive ground? UGH!
Bapsfontein
06-15-2005 00:06:27
I was hoping it would be negative ground. This is an old tractor and has been through a revamp or two, by previous owners. Is there a way to test whether it is actually still positive ground? Is there an easy and cheap way to change it to negative ground?
Tom in Mo.
06-15-2005 17:58:39
 Re: Positive ground? UGH! in reply to Bapsfontein, 06-15-2005 00:06:27
I would guess if you put a battery in it and hit the starter the engine will either turn or it won"t. I doubt that someone would have put a negative ground starter in it.
Positive grounding is just as reliable and reputed to be better than negative grounding in regards to corrosion.
