JD2010 Electrics.
Bapsfontein
06-14-2005 06:08:58
Does anyone know if the JD2010, 4 pod diesel, early 60's model is negative to ground or positive to ground. Is there a way to test this, i.e. on the generator?
Tom inMo.
06-14-2005 18:30:46
 Re: JD2010 Electrics. in reply to Bapsfontein, 06-14-2005 06:08:58
Positive ground. Wiring diagram is in SM-2035
Bapsfontein
06-15-2005 00:06:27
 Positive ground? UGH! in reply to Tom inMo., 06-14-2005 18:30:46
I was hoping it would be negative ground. This is an old tractor and has been through a revamp or two, by previous owners. Is there a way to test whether it is actually still positive ground? Is there an easy and cheap way to change it to negative ground?
Tom in Mo.
06-15-2005 17:58:39
 Re: Positive ground? UGH! in reply to Bapsfontein, 06-15-2005 00:06:27
I would guess if you put a battery in it and hit the starter the engine will either turn or it won"t. I doubt that someone would have put a negative ground starter in it.
Positive grounding is just as reliable and reputed to be better than negative grounding in regards to corrosion.
Bapsfontein
06-14-2005 06:20:33
 12 Volt. in reply to Bapsfontein, 06-14-2005 06:08:58
Forgot to mention, it is a 12 Volt system.
buickanddeere
06-15-2005 06:40:51
 Re: 12 Volt. in reply to Bapsfontein, 06-14-2005 06:20:33
What are you gaining by converting to negative ground?
