Formulas for Distillate
Pat Browning
06-05-2005 14:29:10
Are there known any formulas or mixes to come close to being equal to distillate tractor fuel? Put another way, is there a combination of gasoline, kerosene and diesel fuel that will approximate distillate? I will appreciate all responses -- and if possible, relate which tractor model the mix you are listing was used in. Thanks.
Mike M
06-06-2005 12:08:13
 Re: Formulas for Distillate in reply to Pat Browning, 06-05-2005 14:29:10
I was plowing with my A once and had kerosene in one tank and gas in the other. Switched halfway down the field under load and could tell no difference other than the smell.
buickanddeere
06-06-2005 04:47:18
Jet A or Jet A-1 is what you will find in the US. That's puire refined kerosene, good stuff. 3rd world contries have Jet B which is straight cut off the distillation towers. It's a blend from white gas, kerosene and very light fuel oils. It's what "power fuel" used to be.
Bus Driver
06-05-2005 17:55:55
What I do know is that the tractors equipped for distillate run fine on K-1, no mixing necessary. Any mix of Diesel in a spark ignited engine will have plenty of unburned fuel particles.
randy hall
06-05-2005 17:51:14
my dad drove semis for standard oil in northwest ohio and he had told me that in the early fifties there were still a lot of old john deere guys around mansfield that wanted this cheaper fuel. he told me that they loaded sixty percent gas and forty percent fuel oil and they sold it as 'power fuel'.
Duane Larson
06-05-2005 19:42:49
 Re: Formulas for Distillate in reply to randy hall, 06-05-2005 17:51:14
If I recall correctly, the advantage of "power fuel" was that the tractor would start from cold on it - didn't have to start on gas, warm up, and convert. It was also cheaper than straight gasoline - as I recall it had a nice smell while burning in a '45 A. I have wondered what the makeup was - thanks for the posting!
Caseman2
06-05-2005 16:52:32
Distillate is a cut taken off the fractionator tower while precessing crude oil. Most fract towers had 5 cuts that came off at different hights and temp.s on the tower. the tower being about 90' tall crude oil was pumped in to the bottom of the tower at around 680 degrees F the first cut off was called gasoil, then distillate, keorsene, napatha, and then straight run gasoline went over the top. You might get by mixing gasoline and distillate in tractors that are meant to burn gasoline or kero, but don't try in in a diesel tractor.
Maark
06-05-2005 15:58:33
bought a 44 A once from an old farmer. It was full with a mixture of 3/4 tank of diesel and 1/4 gas. ran very good when switched from gas.
dan_41jdh
06-05-2005 15:49:41
Pat,
Take a look at this thread from a couple of years ago...
Pat Browning
06-05-2005 16:51:51
 Re: Formulas for Distillate in reply to dan_41jdh, 06-05-2005 15:49:41
dan -- once again, thanks for the tip. (PatB)
old
06-05-2005 15:12:41
Back when we used our 1935 JD-B a lot we would use a 50/50 mix of gas and diesel. It sure did pull good that way and at idle it would puff out very large smoke rings. As far as being close to distillate that I'm not sure just know what worked for us
