720 rear wheels
Don Dittmar
05-31-2005 04:46:25
Hello all. I have ran into a snag with the rear wheels on my 720. They are the type where you loosen 3 bolts and tighten 2 and then turn the pinion to move them in and out on the axle. Well, mine seem to be froze up, badly. I have tried liberal amounts of heat and PB Blaster, but they havent moved the slightest bit. Any ideas on what I can do. I would like to take them apart, get them unstuck and working, and sandblast and paint them.
Don Dittmar
06-01-2005 04:21:50
 Re: 720 rear wheels in reply to Don Dittmar, 05-31-2005 04:46:25
Thanks for the advice guys, I will give it a try. I have been soaking it down with PB Blaster, so hopefully some has soaked into it.
Don Dittmar
06-01-2005 04:13:46
Wes Miller
05-31-2005 19:21:36
try loosening the bolts on the inside of the wheel center if this still doesnt free them then beat on the end of the axel with a sledge if all eltse fails you can try driving the tractor a little to free them but be VERY careful
Gerald J.
05-31-2005 11:28:14
Same thing as I wrote about yesterday and the DAY before. http://www.ytmag.com/jd/messages/171315.html
Gerald J.
Mike M
05-31-2005 06:14:46
It sounds like your bolts are free to move. Put some pressure on the 2 jack bolts and then get the biggest sledge you can swing and hit the end of the axle as hard and as square as you can.This method really helps loosen that wedge.
Rich Kevin
05-31-2005 21:21:29
 4430 rear wheels in reply to Mike M, 05-31-2005 06:14:46
I have a 4430 John Deere with the same type of wheels
My problem is I took the tractor to have the wheels moved and the tire guy broke both jack bolts off. the ones that push the wedge out. Any ideas what to do now, so that I can move the wheel.
Mike M
06-01-2005 05:38:11
 Re: 4430 rear wheels in reply to Rich Kevin, 05-31-2005 21:21:29
Some people have made a pipe that fits over the axle,notch the end so it only touches the wedge you need to move it must extend past the end of the axle so you can put a plate on the end and beat on it. I would also try drilling them out and taping the holes for new bolts. If holes are stripped I'd try taping to next oversize and have some bolts made.
