Amt. wear hard to see
Tx Jim
05-07-2005 10:26:34
The syncronizers or drums can have wear in them that without proper specs. and tools can be difficult to determine.What do you think caused the speed range shifter cam to break??Tx Jim
kdagenais
05-07-2005 11:31:19
 Re: Amt. wear hard to see in reply to Tx Jim, 05-07-2005 10:26:34
I would suspect on the cam shifter breaking is by holding it in reverse like you have to right now to get it to move in reverse. That is the problem working on something that you do not know the history of how or why it broke. What would you recommend on replacing if I split this tractor again? If I have to go in there again want to replace all of the narmal wear items and get it over with. The machine has 5300hrs logged on it and runs great otherwise.
MSM
05-07-2005 12:26:50
 Re: Amt. wear hard to see in reply to kdagenais, 05-07-2005 11:31:19
Rebuild/relace all the synchros on the top shaft of the trans while it is out. Might also pay to rebuild the shifter and then set it to spec. Trying to adjust the shift linkage to override a synchro problem usually does more harm than good.Even with new synchros the shifter has to be tight with no slop in the gates and linkage and adjusted properly or you risk taking out a synchro again.
