Hydraulic Pump Shut Off
pbutler
05-06-2005 05:50:33
Any idea where I can get a hydraulic pump shut off for a 4630? I have a tractor with same issue-sure runs good once started but needs the either.
Would love to stop using it too much. New cables helped a lot but I think the pump shut off may really help even more.
jdemaris
05-06-2005 06:10:23
 Re: Hydraulic Pump Shut Off in reply to pbutler, 05-06-2005 05:50:33
I haven't tried to buy one lately, over the counter, from Deere - but it seems they must be available. I used to carry a bag full of them in my toolbox when I was a "road" mechanic for a Deere dealer. They are also pretty easy to make. There are two versions - SAE thread and metric - one or the other will fit any full size hydraulic pump - but not the little German pumps you might find on 820s, 830s, 1020s, etc. The nut/cap on top of your hydraulic pump that is directly inline with the stroke-control valve adjuster on the bottom of the pump - is taken out and a new cap is screwed in. This new cap has a little T handle. You turn it in to shut the pump off, and once the tractor is started, you turn it back out. I drove to a friends place 50 miles from me last week to install one - and come to find out he already had one and didn't even know it. He was shocked to find out what a difference it made once the pump was turned off. If you can't find a part number at your Deere dealer, I'll pull out some of my microfiche and find a number for you. As I said, the only issue - is if the pump has ever been replaced. Most original pumps have SAE threads - but if the pump was ever replaced with a new one, most have metric threads. As far as making one, all you have to do is drill a hole in the cap, thread it, and install a bolt with a T-handle - so when you turn it in, it goes in far enought to put pressure on the end of the stroke-control valve and hold it open. Only problem is, you need a way of sealing it so it does not leak oil. The factory-made unit has an o-ring to seal the T-handle shaft. Deere also has an electric controlled shut-off, that shuts the pump off automatically whenever the starter is engaged. It is VERY expensive. Old pumps need an entire valve-housing replacement to install it and the kit probably costs up around $500. Later pumps already have a bore in the housing ready to accept the electric-shut-off solenoid and have a dummy-plug stuck in the bore. If you have a newer pump with the dummy plug, you can buy just the solenoid and install it - but knowing Deere, just the solenoid is probably $100.
mitchp
05-06-2005 06:48:53
 Re: Hydraulic Pump Shut Off in reply to jdemaris, 05-06-2005 06:10:23
hey jdemaris, i looked on the deere parts website and found one of these T-screws for my 2120. it is part number AR38225. question is, since this is coming from deere, do i simply unscrew the one thats in there now and screw this new one in? or will i have thread differences? also when installing, do i need to wrap the threads with teflon tape?
jdemaris
05-06-2005 10:34:20
 Re: Hydraulic Pump Shut Off in reply to mitchp, 05-06-2005 06:48:53
It depends if your pump is a metric pump or non-metric. I don't even know what a 2120 is - maybe it's Canadian? I've worked on many 1020s, 1520s, 2020s, 2520s, but never seen a 2120.
You just need to know if the threads on the cap you pull out are metric or not. As far as using any thread sealant e.g. teflon tape - it serves no purpose. The original cap, or replacement T-handle unit, has an o-ring for sealing.
F-I-T
05-06-2005 06:31:10
jdemaris:
Any estimate how much cranking hp is gained/lost by removing the pump from the cranking activity? All those early years and I had never heard of that. Of course by the time I headed off to college in '72 and they were finding those innovations out, I was gone. Something to remember if I ever get my hands on a New Generation tractor. I suppose it holds true for something like a 3020D as well?
Frank
jdemaris
05-06-2005 06:54:11
 Re: Hydraulic Pump Shut Off in reply to F-I-T, 05-06-2005 06:31:10
It holds true for any Deere with a closed-center hydraulic system which includes just about all Ag. tractors made after the 1010/2010 series - except for a few of the German tractors like the 830 or the Japanese Yanmar tractors like the 850-1050. I started working for Deere dealers in the 60s, and the hydraulic drag was always a probem with the closed-center system - even with new tractors. Many starter motors have been burnt up because of it. As far as "how much drag", it all depends on the condition of the tractor. The drag gets worse with age - tractors develop small internal leaks that don't affect operation of the tractor, but DO prevent them from starting in cool or cold weather. Such leaks can be in the steering valve, selective control valve, in the pump iself, etc. Some tractors will start better just by jiggling the steering wheel.
thurlow
05-06-2005 08:26:11
 Re: Hydraulic Pump Shut Off in reply to jdemaris, 05-06-2005 06:54:11
Doesn't work quite as good as the shut-off valve, but jiggling (wrestling back and forth)the steering wheel will definitely make a difference. One of the little tricks one picks up..... .you, of course, know this.
