Starting a cold diesel
Bryce
05-05-2005 09:24:53
I just purchased my first diesel tractor. It is an older 4020. My question is what is the proper way to start a cold diesel tracotr? I know I shouldn't use eather, and so far I haven't. But the last few days have gotten cool (in the low 40's) and when I go to start it, it cranks over for quite a while before it finally starts. Should you pump the throttle as you are starting it? Hold it wide open? Leave the throttle alone?
Systor
05-05-2005 22:11:00
 Re: Starting a cold diesel in reply to Bryce, 05-05-2005 09:24:53
I"d add that I don"t use the block heater, I just put my rig inside a quonset each night during the winter. About an hour before I start up my machines each morning, I"ll fire up an electric heater and put it beside whichever rig I want to start first. This helps warm the battery, tires, and differential as well as the engine. I don"t know much about JD equipment, but on an Oliver, if you need to use ether to start it when temp is fairly high (around 40), it means its compression rings are worn or broken and you need a rebuild. Using too much ether can make the tractor "addicted" to ether--it can break compression rings if you use too much. If the rings break, its compression will be lowered so much you will have to use ether all the time to start it if the temp is below about 35 degrees.
jdemaris
05-05-2005 20:38:46
Some 4020s when new were good starters down to 20 degrees F, and some wouldn't start unless it was 50F. All depends on the machining tolerances when it was built - which were sloppy with all the Deere engines until the late 1980s. To compound the issue, often an engine rebuild along with a valve job often makes them start worse. Valve depth in head, along with head-gasket thickness is critical. In regard to ether use, if used correctly the engine will handle it fine. You can also ruin the engine with it. Deere used a factory installed ether injector that prevented ether overloading. But, many older tractors no longer have it hooked up, and ether is shot into the air intake instead - which can break the top piston rings if too much is used. If you want the best starting possible - the most important thing to do is install a manual hydraulic pump shut off. It will cost around $5 and take five minutes to install, and the tractor will start MUCH better with it. Second, use the block heater when possible. If you want to use ether safely, hook up the factory ether injector (hose and nozzle in intake). In regard to throttle position - the fuel metering valve is usually at "full-wide open" position regardless of where the throttle control lever is when the engine is not running. But, it can't hurt to put it up to full position when starting just to be sure.
pbutler
05-06-2005 05:50:33
 Hydraulic Pump Shut Off in reply to jdemaris, 05-05-2005 20:38:46
Any idea where I can get a hydraulic pump shut off for a 4630? I have a tractor with same issue-sure runs good once started but needs the either.
Would love to stop using it too much. New cables helped a lot but I think the pump shut off may really help even more.
jdemaris
05-06-2005 06:10:23
 Re: Hydraulic Pump Shut Off in reply to pbutler, 05-06-2005 05:50:33
I haven't tried to buy one lately, over the counter, from Deere - but it seems they must be available. I used to carry a bag full of them in my toolbox when I was a "road" mechanic for a Deere dealer. They are also pretty easy to make. There are two versions - SAE thread and metric - one or the other will fit any full size hydraulic pump - but not the little German pumps you might find on 820s, 830s, 1020s, etc. The nut/cap on top of your hydraulic pump that is directly inline with the stroke-control valve adjuster on the bottom of the pump - is taken out and a new cap is screwed in. This new cap has a little T handle. You turn it in to shut the pump off, and once the tractor is started, you turn it back out. I drove to a friends place 50 miles from me last week to install one - and come to find out he already had one and didn't even know it. He was shocked to find out what a difference it made once the pump was turned off. If you can't find a part number at your Deere dealer, I'll pull out some of my microfiche and find a number for you. As I said, the only issue - is if the pump has ever been replaced. Most original pumps have SAE threads - but if the pump was ever replaced with a new one, most have metric threads. As far as making one, all you have to do is drill a hole in the cap, thread it, and install a bolt with a T-handle - so when you turn it in, it goes in far enought to put pressure on the end of the stroke-control valve and hold it open. Only problem is, you need a way of sealing it so it does not leak oil. The factory-made unit has an o-ring to seal the T-handle shaft. Deere also has an electric controlled shut-off, that shuts the pump off automatically whenever the starter is engaged. It is VERY expensive. Old pumps need an entire valve-housing replacement to install it and the kit probably costs up around $500. Later pumps already have a bore in the housing ready to accept the electric-shut-off solenoid and have a dummy-plug stuck in the bore. If you have a newer pump with the dummy plug, you can buy just the solenoid and install it - but knowing Deere, just the solenoid is probably $100.
mitchp
05-06-2005 06:48:53
 Re: Hydraulic Pump Shut Off in reply to jdemaris, 05-06-2005 06:10:23
hey jdemaris, i looked on the deere parts website and found one of these T-screws for my 2120. it is part number AR38225. question is, since this is coming from deere, do i simply unscrew the one thats in there now and screw this new one in? or will i have thread differences? also when installing, do i need to wrap the threads with teflon tape?
jdemaris
05-06-2005 10:34:20
 Re: Hydraulic Pump Shut Off in reply to mitchp, 05-06-2005 06:48:53
It depends if your pump is a metric pump or non-metric. I don't even know what a 2120 is - maybe it's Canadian? I've worked on many 1020s, 1520s, 2020s, 2520s, but never seen a 2120.
You just need to know if the threads on the cap you pull out are metric or not. As far as using any thread sealant e.g. teflon tape - it serves no purpose. The original cap, or replacement T-handle unit, has an o-ring for sealing.
F-I-T
05-06-2005 06:31:10
jdemaris:
Any estimate how much cranking hp is gained/lost by removing the pump from the cranking activity? All those early years and I had never heard of that. Of course by the time I headed off to college in '72 and they were finding those innovations out, I was gone. Something to remember if I ever get my hands on a New Generation tractor. I suppose it holds true for something like a 3020D as well?
Frank
jdemaris
05-06-2005 06:54:11
 Re: Hydraulic Pump Shut Off in reply to F-I-T, 05-06-2005 06:31:10
It holds true for any Deere with a closed-center hydraulic system which includes just about all Ag. tractors made after the 1010/2010 series - except for a few of the German tractors like the 830 or the Japanese Yanmar tractors like the 850-1050. I started working for Deere dealers in the 60s, and the hydraulic drag was always a probem with the closed-center system - even with new tractors. Many starter motors have been burnt up because of it. As far as "how much drag", it all depends on the condition of the tractor. The drag gets worse with age - tractors develop small internal leaks that don't affect operation of the tractor, but DO prevent them from starting in cool or cold weather. Such leaks can be in the steering valve, selective control valve, in the pump iself, etc. Some tractors will start better just by jiggling the steering wheel.
thurlow
05-06-2005 08:26:11
 Re: Hydraulic Pump Shut Off in reply to jdemaris, 05-06-2005 06:54:11
Doesn't work quite as good as the shut-off valve, but jiggling (wrestling back and forth)the steering wheel will definitely make a difference. One of the little tricks one picks up..... .you, of course, know this.
Ken S.
05-05-2005 19:38:26
I would use the block heater and if needed when really cold a sniff of either. About 1/4 to 1/2 throttle.
720Deere
05-05-2005 19:37:24
You have gotten good advice. I just sold a '66 4020 this winter that ran like a champ and turned 96 hp on the dyno and it did not like to start below the mid 40s. Even had a new starter and good batteries, but the wiring could have been spruced up. If you have a good coolant heater/circulator, a little over an hour is all it should take to get her going. No need to leave it plugged in all night unless it is brutally cold.
The best benefit of the heater is that the engine doesn't have to scrape and bank it's way up to temperature when it's extremely cold. It could save mucho startup wear as well as prevent busted rings from ether use.
F-I-T
05-05-2005 13:54:31
Bryce:
The guys are right on with their advice. We had a "64 4020, which was the first year they were out. We used a bit of ether in it the first couple of years, then it seemed "kinder" to have a JD block heater installed, the kind that pumped and pulsed the coolant through the block. That started in any temp in an Ohio winter, at least any temp in which we needed to work, but judicious use of ether never really hurt it, but as time went on we tried to use the block heater as much as we could.
Frank
thurlow
05-05-2005 12:10:02
Judicious use of ether is not gonna hurt a 4020; they even came from the factory with injection device..... .el shaped unit just under steering wheel.
buickanddeere
05-05-2005 09:30:19
Engine coolant heater. Extended cranking quickly shortens the life of all the tractors electrical components. Batteries, charging system, starter and switch(s). Ther are injection pump secrets that other board members know that may help some.
Bryce
05-05-2005 10:32:17
 Re: Starting a cold diesel in reply to buickanddeere, 05-05-2005 09:30:19
Yeah, it does have a coolant heater on it, but I assumed that was for cold/winter months.....should I have to use it now? Would a snort of ether be that bad from time to time?
txgrn
05-06-2005 06:22:15
 Re: Starting a cold diesel in reply to Bryce, 05-05-2005 10:32:17
Some tractors come equipped with ether injection so it can't be all bad.
I use it SPARINGLY. Seems if I add it to the entrance of the air cleaner, it gets dispersed and my engines fire off smothely; no banging and clanging like if you put it directly into the intake manifold..... although that's where the factory injection systems on some tractors have it.
It saves a bunch of wear and tear that b&d was talking about.
SPARINGLY. Start spinning the engine and then squirt a prsssss sssss sssss ssst into the air inlet. Give it a couple of seconds to get to the cylinders and you should be good to go.
Mark
buickanddeere
05-05-2005 12:54:39
It's a 33+ year old tractor. No shame in using a block heater at 45F for an hour. Even when new, those old open chamber style diesels had trouble starting at freezing temps. Factory equiped with ether inection or not.Most times ether is used, knocking and rattling can be heard. A block heater has to be less stress?
Bryce
05-05-2005 13:08:31
 Re: Starting a cold diesel in reply to buickanddeere, 05-05-2005 12:54:39
Makes perfect sense. Thanks for your input.
Jim in AK
05-06-2005 00:28:55
 Re: Starting a cold diesel in reply to Bryce, 05-05-2005 13:08:31
I have a 1964 4010D. I live in Alaska 62 miles North of Anchorage in Willow.
I removed the ether injector because I never used it. I use a 1500 W coolant heater before starting if weather is 40�f or colder, down to 0�. I have started it as cold as -30�f but that time I also used an LP fired heater on the crank case to warm the oil. I normally don't even try to start her in temps below 0�. The trick is HEAT, not the stuff in the little yellow bottle, the BTU kind.
Jim
