Fuel gauge switch
WeirdDeere
05-03-2005 01:04:03
Hey JohnT, since you're talking about the fuel gauge switch, I would like some advice with mine.
Mine seems to be an original. Three terminal, but it doesn't operate like I thought it should (nor per your description).
If the button is out NONE of the terminals are connnected. If I push it in, ALL of the terminals are connected.
I thought I might have swapped it with the starter switch, but that also operates the same way.
Right now I have it wired up this way:
Wire from generator AND wire to gauge on one terminal. Wire from ammeter on another. So when not running, I press the button, and get juice from the ammeter (also makes ammeter show a discharge-I assume from sending power to generator) When the tractor is running, power from the generator goes right to the gauge. It seems to work just fine.
Do you think I will hurt anything keeping it this way?
Brandon
John T
05-03-2005 07:33:18
 Re: Fuel gauge switch in reply to WeirdDeere, 05-03-2005 01:04:03
Deere, NO, I dont see it as hurting anything so log as you DO NOT push the switch. When you do youre applying battery power via the ammeter to the Gens armature which is trying to make it run as a DC motor and heating it up plus maybe exceeding the switches ampacity. The gauge works as you mentioned when shes running, cuz it is connected directly to the Gens armature so it has a voltage supply.
My best guess is you have the ammeter wired to the switches common POLE (see below),,,,, ,,one throw has BOTH the gauge and Gen wired to it,,,,, ,the other throw has nuttin. IF IT WERE MINE I WOULD RE WIRE IT CORRECTTLY AS ITS SO SIMPLE N EASY that way you can check the fuel not running by pushing the button but when shes running it works regardless.
This is sooooo oooo simple if there and I will try n describe it which may not be so simple.
The switch is a single COMMON POLE (which wires to gauge) with two THROWS (one to Gen N/C other to ammeter N/O). If you have a battery powered continuity checker or an ohm meter heres how to tell which is which.
Take the switch NOT PUSHED and 2 terminals should show continuity. OK one of them is the POLE and other is one of the throws. Next, with SWITCH PUSHED, two terminals will show continuity. THE TERMINAL that shows continuity somewhere in BOTH positions (push or not) is the common POLE and wires to the gauge. The N/C terminal thats connected (to common POLE) NOT PUSHED wires to the Generator while the N/O terminal that shows continuity to the POLE WHEN PUSHED wires to the ammeter.
Clear as mud???? Like I said above, I suspect from your description the ammeter is now wired to the common POLE terminal,,,,, ,,your gauge and Gen are wired to the Normally Open (N/O) throw terminal, and the Normally Closed (N/C) wired to nuttin. That way when depressed youre sending battery power (via ammeter) to the Gen making her try n motor, while not depressed the ammetr lead is just sitting there but the gauge works when running via Generator voltage.
MAYBE,,,,, ,,, remove the gauge from where its wired now and re wire it to where the ammeter is wired now,,,,, ,,remove the ammeter from where wired now over to that unused throw IM NOT SURE LOL IM IN A HURRY geting ready to go to take the First Wife in our Motorhome to Lake Barkley a few days. HOWEVER, Im sure fo my prior wiring method and description but the immediatee foregoing was a lil rushed for my old brain.
Lemme know when I return
Ol John T
