730d pony start
kenworth
05-02-2005 11:20:48
need some help and advice on re-wiring a 730d w/pony start motor. i tried to re-wire tractor using colored wire but ended up with a short. i purchased a new complete wiring harness for this tractor. problem is that the fuel level indicator gauge in the dash reads, what is in the tank all the time. i know the switch button is to be pushed in to make the gauge work corectly. also the amp meter reads the wrong way.it shows charging when the switch is turned on and shows discharging when the big diesel motor is running. also the blue wire running to the starter solenoid sparks when hooked to the post. i wired it up according to the john deere parts manual for this tractor. any and all help will be greatly appreciated. i am becoming weary of this problem. hand gernades my be my next option. thanks again
Spoker
05-02-2005 18:38:30
 Re: 730d pony start in reply to kenworth, 05-02-2005 11:20:48
John T is correct and follow his advise. I had the same problem when I rewired my 720 D Standard with pony start. What I wound up doing was to pull the dash and wires. Layed it next to the diaghram and checked each wire and switch. Ohmed each push buttom and gauge. I found that I had crossed a couple of wires on two switches. (Post positions) and when I switched them it worked. I put the dash and wires back in and tried one wire at a time to the Reg., Fuel Gauge, Solinoid, Distributor on pony. If I got no spark when I touched the componates Then I was sure I had the wires in the dash correct. Every thing works like it should. Good like. It took me what seemed to be a full day to get it right, but it really took a half a day. Watch the diagrahm and land the wires carefully. Oh I also found that the dust on some of the gauges cause or seemed to cause a small short..
John T
05-02-2005 12:44:51
Kenworth, if the color code aint right, about all you can do is get a test lamp or voltmeter and maybe a continuity checker and go to work armed with an understanding of how things work then wire em that way.
1) This assumes youre wired at Positive Ground as she was originally???? If shes been reversed, the ammeter would read bass ackwards. CHECK THAT FIRST. If it was wrong reverse the battery and repolarize the Generator. If thats NOT the problem, sounds like the ammeter is obviously wired bass ackwards which a side to side wire swap might cure. However, the ammeters hot input supply terminal (only 1 wire there) needs to be connected to the hot ungrounded battery post via the starter or elsewhere, while all loads and the Generators output (via the BAT terminal on the VR) are all over on the other load side of the ammeter. My diagram shows the ammeters load side with 2 wires, black to fuel gauge switch and white to BAT terminal on the VR, with the input supply terminal using a white wire down to the starter.
2) That fuel gauge selector switch works as a single pole double throw 3 terminal switch with its common "pole" terminal wired to supply voltage to the fuel gauge, which it gets EITHER from one "throw" wired to the ammeter or the other "throw" wired to the Voltage Regulators ARM post. When depressed and engine not running, it makes the fuel gauge work by using the switch to supply battery voltage (via the ammeter) but when the Gen is turning and the button not depressed the fuel gauge works cuz it gets voltage via the switch from the Generator (VR"s ARM terminal). With the engine not running, the wire thats always hot wires to the switches "throw" from the ammeter,,,,, ,,,,, ,the wire that turns hot when the Gen is turning wires to the switches other "throw",,,,, ,,,the switches common "pole" is what feeds voltage to the fuel gauge.
3) On that wire to the starter solenoid, is it wired to the correct push to start switch terminal???? It shouold be wired to whichever push to start switch terminal that only turns hot when its depressed.
Sorry, this is one of those things thats fairly easy to wire if there and armed with a test lamp or voltmeter, but a lil hard to explain over the net. Maybe this will help or it may cornfuse you even more.
Lemme know, \\
John T
WeirdDeere
05-03-2005 01:04:03
 Fuel gauge switch in reply to John T, 05-02-2005 12:44:51
Hey JohnT, since you're talking about the fuel gauge switch, I would like some advice with mine.
Mine seems to be an original. Three terminal, but it doesn't operate like I thought it should (nor per your description).
If the button is out NONE of the terminals are connnected. If I push it in, ALL of the terminals are connected.
I thought I might have swapped it with the starter switch, but that also operates the same way.
Right now I have it wired up this way:
Wire from generator AND wire to gauge on one terminal. Wire from ammeter on another. So when not running, I press the button, and get juice from the ammeter (also makes ammeter show a discharge-I assume from sending power to generator) When the tractor is running, power from the generator goes right to the gauge. It seems to work just fine.
Do you think I will hurt anything keeping it this way?
Brandon
John T
05-03-2005 07:33:18
 Re: Fuel gauge switch in reply to WeirdDeere, 05-03-2005 01:04:03
Deere, NO, I dont see it as hurting anything so log as you DO NOT push the switch. When you do youre applying battery power via the ammeter to the Gens armature which is trying to make it run as a DC motor and heating it up plus maybe exceeding the switches ampacity. The gauge works as you mentioned when shes running, cuz it is connected directly to the Gens armature so it has a voltage supply.
My best guess is you have the ammeter wired to the switches common POLE (see below),,,,, ,,one throw has BOTH the gauge and Gen wired to it,,,,, ,the other throw has nuttin. IF IT WERE MINE I WOULD RE WIRE IT CORRECTTLY AS ITS SO SIMPLE N EASY that way you can check the fuel not running by pushing the button but when shes running it works regardless.
This is sooooo oooo simple if there and I will try n describe it which may not be so simple.
The switch is a single COMMON POLE (which wires to gauge) with two THROWS (one to Gen N/C other to ammeter N/O). If you have a battery powered continuity checker or an ohm meter heres how to tell which is which.
Take the switch NOT PUSHED and 2 terminals should show continuity. OK one of them is the POLE and other is one of the throws. Next, with SWITCH PUSHED, two terminals will show continuity. THE TERMINAL that shows continuity somewhere in BOTH positions (push or not) is the common POLE and wires to the gauge. The N/C terminal thats connected (to common POLE) NOT PUSHED wires to the Generator while the N/O terminal that shows continuity to the POLE WHEN PUSHED wires to the ammeter.
Clear as mud???? Like I said above, I suspect from your description the ammeter is now wired to the common POLE terminal,,,,, ,,your gauge and Gen are wired to the Normally Open (N/O) throw terminal, and the Normally Closed (N/C) wired to nuttin. That way when depressed youre sending battery power (via ammeter) to the Gen making her try n motor, while not depressed the ammetr lead is just sitting there but the gauge works when running via Generator voltage.
MAYBE,,,,, ,,, remove the gauge from where its wired now and re wire it to where the ammeter is wired now,,,,, ,,remove the ammeter from where wired now over to that unused throw IM NOT SURE LOL IM IN A HURRY geting ready to go to take the First Wife in our Motorhome to Lake Barkley a few days. HOWEVER, Im sure fo my prior wiring method and description but the immediatee foregoing was a lil rushed for my old brain.
Lemme know when I return
Ol John T
