#1 What do you disagree with in regard to, as you state, my �French� pronunciation? I AM French so have some knowledge on the matter. As I�m sure you know, there is not one standard that all the French people use - that goes for speaking or writing. The French government maintains standards for the �official� government recognized language, whereas many rural people have their own regional dialects and sometimes totally different languages. My parents and grandparents, who were farmers in southern France, department Ari�ge, spoke Catalan as their everyday language or patois - and only spoke French to people who were considered outsiders of their village. French Canadians speak a language that is closer to historical French then what people in most of France now use. Please provide your corrections.#2 You mention the resistor- bypass system as being the only bypass system, and that is, plain and simple, wrong. Many systems, including the original Auto-Lite systems, use a temperature sensitive resistor which allows full current to the coil when the ignition is first turned on - without the use of a bypass. Other companies, e.g. Delco, chose to use resistors of fixed resistance and a mechanical means of bypassing the resistor during cranking. And, as aforementioned, many systems during the early 1900s used resistors in 6 volt systems to limit current draw in situations when the ignition was left on, the engine was not running, and the breaker points happened to be closed. #3 You state that putting a resistor inside a coil does not make sense. Well, maybe not to you, but it did to others, it was common - and you not believing it doe not change history. That was during the time when many coils could be disassembled for repair if necessary, just as batteries and spark plugs used to have replacement parts available. #4 You state your comments relate to supporting accuracy in this forum? Okay. List some of your specific disagreements, and I will post my source citations, and compare them to your�s. Let me add that, although I have a rather large library of documents and books starting in the late 1800s to present, I have also seen or worked on many of the systems or components we are discussing. And, I invite discussion as long as the facts used are valid and cited. John Alexandre P�tronille de Marrais Cotter�ts (am I pronouncing my full name right?)
