I pretty much disagree with your French pronunciations. I was in the middle of an answer and the power went off and I don't feel like going thru it again, but you aren't exactly correct in your analyses. I'll agree that the higher the combustion pressure of an engine, the more voltage it takes to jump a given spark. That's why you have problems with high voltage at altitude. Low pressure (space is a vacuum) means lower voltage required to jump a given gap; conversely higher pressure needs higher voltage. "Varnish" is used in coil windings and it can be made up of numerous chemicals. Purpose is to insulate wire, tolerate vibrations and not scratch off, tolerate rated temperature, and be very thin (like a couple of mils thick) so as not to appreciably add to the winding volume. Interconnects from the coil to external terminals can have the cotton insulation or teflon or raychem plastic etc. The bypass function on ignition coils was used during engine starting so as to put 12 volts on a 6v coil to double the voltage output. Once the ignition key was released, the ballast resistor was returned to the circuit to lower power dissipation in the coil and subsequently reduce the plug voltage. To put the resistor, as a physical element, inside the coil requires volume and doesn't make a lot of sense considering dissipation and what that does to the coil temp which affects the permeability of the iron core and the ability of the insulation to tolerate heat. However I don't know personally that it wasn't done. Ignition points break an inductive circuit. The inductive current in the ignition coil will not immediately stop and that attempts to cause an arc across the opening contact (L di/dt). That means that they have to be made to tolerate and disrupt inductive energy for many thousands of operations. The ignition condenser (capacitor) is designed to absorb this energy at a rate that will allow the circuit to break (at the engines rated max rpm's), yet maintain the voltage across the points below the arc value (so the points don't burn out in a few hours of operation)....which depends upon how fast the current can be applied thru the circuit resistance. Points are like any other switch. They have to have ratings and with what I have learned about ignition systems, 4 to 5 amperes is a good number. Shall I go on? Not that it makes any difference to me, but a lot of people use ignition systems and read these threads and the data needs to be as accurate as we can make it.....even though I get lazy sometimes and guess without going out to my tractors and looking. Best, Mark
