?'s answered (I'll try anyway!)
Mr Zak
02-14-2005 18:36:50
I"ve had both a 45" and a 48" A and went through them from front to back and I even remember some of the things you are asking about. No, there is no connection between the mag/distributor and the throttle. Ya either have a grounding tab on the mag (not alwasy there) or a wire from inside the mag running to a key (not always there either!). If you have a distributor, there is usually a stud protruding from the side of the cap that one can wire a keyed ignition switch to allow for a shutoff. Only other way (and the best way really) is to shut off your fuel and let "er run the line dry. Why is this way best? Cause you"ll not forget to turn your fuel off. Important? Yeah, cause if you happen to have a leaky carb/fuel valve (not likely with a newly rebuilt one but still...) you can actually fill (I mean FILL) a cylinder with fuel which will have an interesting consequence. As the cylinder is coming up to a compression stroke, you"re gonna bend a rod. Not good.
Styled tractors come in two flavors, early and late (You thought this was easy huh ;). Early styleds have straigh frame rails (looks like flat stock) while the lates have pressed, heavier frame rails. There are more differences before anyone jumps in and bites my head off, but this will get you by for now. The unstyled series don"t have much in the way of tinwork, most notably, an exposed radiator. Usually, your tinwork on an unstyled consists of a hood sheet and that"s about it. Check out some of the pics over on www.Johnnypopper.com for more info. (Sorry about posting another site on here but it"s also agood one). Later, Zak
