I am assuming you have a styled A, but don't know. There should be a wiring diagram in the Parts catalog. For a styled A (S/N 477000 & up), you need PC675. For S/N 476999 & below, you need PC674. This document is available from Deere Pubs (800) 522-7448. You can also obtain an Operators Manual from them too. Here there is four different ones depending on the S/N of your tractor --DIR103 for 476999 & below, OMR 2000 for 477000 thru 583999, OMR 2001 for 584000 thru 647999, OMR 2002 for 6480000 and up. The Operators Manual will have engine shut down instructions. What ever you do, stopping the engine by taking away its ignition is not right. Take away its fuel -- this way there remains no unburned gas in the cylinder chambers at shut off. Fuel left behind here "washes" the cylinder walls, breaking down the oil film. This, in turn, reduces compression -- and can make for hard starting. I do not believe (could be wrong here) that there is any connection between the throttle and ignition. As for an oil additive, there are some products out there like Mystery Oil for instance -- check with your local NAPA store for starters. Finding an oil "stop leak" can be tricky. 'Hope this help. (PatB)
