Additional thoughts to check.......
JD Jack
02-08-2005 19:23:16
Just as a precaution I would suggest checking and replacing as needed a few more parts than just pistons and sleeves. If you expect the tractor to last a long time after this rebuild it is in your best intrest. If any of these things listed below fail, you will be out an additional $1600 for another rebuild kit plus any more costs. Check the oil pressure to be sure the oil pump is working properly. Also I would rebuild or get rebuilt injectors. I believ the 4010 has the big ones like the early 4020s, so new ones aren't available. Check the cam gears, if they have sharp teeth, they are wore and should be replaced. Check the crank and the rod bearings and also have the head and valves gone through by a good machine shop. I would hate to see you spend a decent amount of money on a shabby rebuild and then end up ruining the motor and doing it all over again.
