more 4010 Anti-freeze
R. John Johnson
02-07-2005 21:06:55
Did some more checking around. I can get a overhaul kit locally for $1660 CDN. I am going to do the work myself in the spring after calving is done and the weather warms up. I know I will have to buy a click type torque wrench, a set of dial calipers, and a JD service manual. Anything else that I will need? I see there is a manual on e-bay right now with a starting bid of $75. Is this a good price or should I keep looking? as usual, any advice is appreciated.
John
buickanddeere
02-09-2005 01:54:15
 Re: more 4010 Anti-freeze in reply to R. John Johnson, 02-07-2005 21:06:55
Grinding valves and seats leaves them sunken. This doesn't look important until the compression ratio is calculated. Then the resulting poor cool weather starting cause becomes apparatnt. Pretty much stuck with new valves and seats as well. The price on these jobs can get out of hand pretty quick when looking everyhing over.
JD Jack
02-08-2005 19:23:16
 Additional thoughts to check....... in reply to R. John Johnson, 02-07-2005 21:06:55
Just as a precaution I would suggest checking and replacing as needed a few more parts than just pistons and sleeves. If you expect the tractor to last a long time after this rebuild it is in your best intrest. If any of these things listed below fail, you will be out an additional $1600 for another rebuild kit plus any more costs. Check the oil pressure to be sure the oil pump is working properly. Also I would rebuild or get rebuilt injectors. I believ the 4010 has the big ones like the early 4020s, so new ones aren't available. Check the cam gears, if they have sharp teeth, they are wore and should be replaced. Check the crank and the rod bearings and also have the head and valves gone through by a good machine shop. I would hate to see you spend a decent amount of money on a shabby rebuild and then end up ruining the motor and doing it all over again.
Gerald J.
02-08-2005 08:33:10
Be sure its the right manual, TM-2039 as I recall for 4010 and early 4020. The later manual for 4020 won't cover either the 4010 or the early 4020.
The I&T shop manual has some useful insights but presumes much knowledge and skips details sometimes, but its a good introduction.
There will be a few more tools needed, like one for the flywheel seal and the splitting tools if you get that far into the tractor to replace mains.
Gerald J.
Mike M
02-08-2005 05:22:35
As far as the manual goes just buy a new one from Deere as it might be cheeper. Those things go high on ebay.
