90W in power shaft cover - housing
720 2840
02-03-2005 13:20:32
I need to replace the gasket between the pto clutch housing and power-trol unit. When went to drain it I got 10 + or - gals. of 90W instead of the 4 1-2 qts. of 10W I was expecting. I assume it is coming form the trans,throgh the clutch drum shaft? Is it and how do you fix this? In all the service manuals, I have not seen this even metioned. Help!!! Its driving me nuts!!!
John Van Valkenburgh
02-06-2005 21:13:24
 Re: 90W in power shaft cover - housing in reply to 720 2840, 02-03-2005 13:20:32
Your 720 PTO should be similar to my 50. I had to fix this problem last year. Its likely that the PTO Pump seal is leaking. I posted a picture in a later post that shows this seal.
Let me know if I mess up the link to that post....
John
1953 Model 50
DaveH IA
02-03-2005 15:26:07
You now get to remove the complete rockshaft housing from the rear end and replace the seal in the gear pump housing on the input shaft for the PTO
Mike N Mo
02-03-2005 16:55:43
 Re: 90W in power shaft cover - housing in reply to DaveH IA, 02-03-2005 15:26:07
Hopefully all that is wrong is the seal on the shaft. When my 60 had the same problem the casting around the input shaft bearing (brass bushing) was worn (I assume from the bearing spinning in the bore). I put a new bearing in using steel epoxy to repair the casting, and hasn't leaked in 8 years. Mike
