1937 AR valve lash
Newby KC
01-21-2005 14:34:36
Anyone know the correct valve lash for a 1937 Model AR. 254000? I think it should be approx. .011", but not sure. Also, interested in the head nut torque. Thanks!
Clooney
01-21-2005 14:55:20
 Re: 1937 AR valve lash in reply to Newby KC, 01-21-2005 14:34:36
KC, Deere didn�t publish torque values for tractors as early as 1937 as no one had torque wrenches on the farm back then.
I always use the later �A� cyl head torques of 125� lbs..
On the valve lash.. that is .020� hot.. If your valve train has a lot of wear don�t use a feeler gauge but instead tighten the valve adjuster with one hand while moving the pushrod in & out with the other,, just as the push rod play comes out (O-lash)-stop,, then back the adjuster off 1/3 turn (2 nut flats if the nut moves with the adjuster) that will leave you right around .020� & won�t be inaccurate on the worn parts like a feeler gauge will. Make sure you are on the base circle of the cam when adjusting (valve lifter at lowest point)..
Clooney
Lee B
01-22-2005 01:36:41
 Re: 1937 AR valve lash in reply to Clooney , 01-21-2005 14:55:20
Clooney, could you take a look at Michael's discoveries and mark my 43 A down as having the same 'defect' and then ponder out loud as to what the heck might be going on? TIA.
A link to Michael's post is at the bottom of this post (I hope).
I found that the base circle appears to have .035 clearance some 30 crank degrees before each specific valve begins to open. At compression/fire TDC the clearance is some .010 to .015 tighter which makes accurate valve clearance setting a bit troublesome at least in theory. My rocker arm valve stem surface is worn a good deal and I did use very narrow (1/8 inch) feeler gauges to determine the above clearances with so precise accuracy probably not achived. I also found the right side rocker arm shaft to move visibly only just barely detectably which only adds to the inaccuracies. Anybody else care to testify on the .035 clearance at 30 degrees before valve opening, please join in.
Clooney
01-22-2005 06:05:57
 Re: 1937 AR valve lash in reply to Lee B, 01-22-2005 01:36:41
third party image
Lee I don't doubt that at all.. 60+ years of wear will do that to most rotating parts.
Number one on the list would be the cam bearings (L/H more than R/H)..
Next, would be just basic wear on the cam & tappets..
I guess if it bothers you pull the cam & have it re-ground, check the bearings, replace the cam gear, have the tappets surfaced, take all the slop out of the rocker arms & rocker shaft..
If you look at the way most solid lifter cams are ground you have the basic base circle,, then you have very a slow lift take up ramp to slowly bring the tappet from the base circle to the actual start of lift,, then you have the opening flank lift, then top of lobe dwell,, then closing flank, then closing ramp, then back to basic circle..
When a valve adjusting clearance is figured it is basically figured to allow the tappet to come off the base circle cleanly & be at about (0) lash just as the tappet gets to the opening flank.
Too little valve lash allows the valve to start opening on the slow �opening ramp� so valve burning is possible do to slight flow through a small opening & if the valve is even slightly off it�s seat on the opening & closing ramps it isn�t cooling on the valve seats. (you really don�t want to open the valve on the opening ramp)..
Too much valve lash opens the valve well up into the fast part of the opening flank.. That snaps the valve open quickly & is hard on valve train parts & is noisy & will also drop the valve quickly on the closing flank so valve bounce could occur. Basically too much lash by-passes the opening & closing ramps so valve action is harsh.. Like backing your tractor off your trailer without using ramps.. (if you haven�t ever done that let me tell you it�s harsh)
Now on your question of: one or two spots on the base circle where you have extra valve lash.. You don�t want to set your valve lash setting there.. It means nothing & can cause your lifter to be incorrect as it enters & leaves the opening ramp part of the cam.
Probably the best place to make a valve lash adjustment is on the base circle just before the tappet gets to the opening ramp as that would allow the opening ramp to do it�s thing & have the valve train at (0) lash just as the tappet gets to the opening flank.. That would be hard to do so most are set on the meaty part of the base circle.
A little extra valve lash is much better than a slightly tight valve but does leave them noisy..
Usually a factory valve lash setting is designed to MAKE SURE any variation in the base circle clears the tappet so the tappet easily clears the base circle without any possibility of tappet lift even when extremely hot or cold. Any undulations in the cam base circle really means nothing as the tappet isn�t doing anything there anyhow..
The above is on a solid lifter cam only.. Hydraulic cams are different as the opening & closing ramps aren�t needed..
There is a lot more to camshaft dynamics than shown above but this should basically answer your question..
Clooney
