49 John Deere A valve adjustment
Michael Wheeler
12-08-2004 17:42:34
Can someone please help with the proper procedure for adjusting the valves on a 49 John Deere A. I have adjusted them at .020 cold and hot with piston at TDC combustion stroke for each cylinder. Tractor idles and runs great at this setting but has a lot of valve clicking noise. With the valve cover off and engine running I can put a .035 feeler gauge between valve and rocker arm. I found that there is a place in the crankshaft rotation where each valve has about .035 clearence. All help appreciated.
Lee B
12-10-2004 00:12:44
 Re: 49 John Deere A valve adjustment in reply to Michael Wheeler, 12-08-2004 17:42:34
You appear to be doing it 'by the book' sure enough and because of your extra diligence may have discovered a wide spread 'defect' in Mother Deere's cam grinding scheme - IF as you say, each valve has the .035 at some point. My 43 A is set to .020 at ignition point just like yours and also has a lot of clatter which I don't like at all as that indicates hammering and excessive wear from same.
I can't promise I'll get to it right away but after checking those cam bearings I'll look at mine and if I find .035 at some point on EACH valve as you have, I'm going to use 0.10 as base starting point for ignition point clearance and be quite satisfied about the whole deal - thanks a bunch for the eagle eye in spotting this. Perhaps .020 IS good enough, IF we do it a maximum clearance point which turns out to NOT be the ignition point as common sense would seem to indicate that it would be? Perhaps a sentence outlining the use of the actual maximum clearance position has long been omitted in the manuals due to simple oversight? Again thanks for the heads up. Sharp eye.
Goodwrench
12-09-2004 10:04:58
Like the gentleman says below, check both cam bearings to be certain the cam isn't "walking". Many of the LH bearings are bad, especially if the tractor has set for a bit.
Removing the taper bearing will not be much fun, but I've had OK results with a heat & pull method after the cone is removed. Make sure you are wearing a welder's apron, as they can get a little frisky when they pop off.
Earl S.
12-08-2004 19:47:51
Is your cam timing checking out?? Earl
Mike M
12-08-2004 18:55:30
I have never tried to check a 2cyl. running.Have done this on some others. Have you redressed the faces of the rocker arms so you can get a more accurate reading ? I redress my rocker arms then set them at .022 cold at TDC on compression stroke and run them,never had a problem.Those late A's and B's will be noisy compared to other models for some odd reason.To loose is better than to tight,I once had someone tell me they set their intake valves around .030 to keep them from burning,but I just set mine by the book and seem to not have any trouble.Just had a thought ? Since you have an A model that left hand cam bearing is a common problem to go bad this could cause your cam to jump around it's settings I'd check it before I did anything else I have seen plenty of them bad.
