1941 john deere b pops out of 2nd
c jim
01-05-2005 15:30:09
1941 john deere b pops out of 2nd gear, while coming down hill with a load of wood and in 2nd gear transmission popped out of gear got it stopped (luckly)the shift lever was still in 2nd gear postion pulled shifter back into neutral and then back into 2nd and was fine the rest of the day, rest of the trips when came down the hill had in 1st, what caused it to pop out of gear, but when shifted to nutral then back to 2nd was normal(was in low range)
Clooney
01-05-2005 16:15:03
 Re: 1941 john deere b pops out of 2nd in reply to c jim, 01-05-2005 15:30:09
Jim, if it popped out of 2nd & the lever stayed in the slot you popped out of over/under drive.. That is usually a loose or worn out trans bearing problem as that allows the top trans shaft to move sideways & decouple the top shaft from the trans input shaft.. But it could also be shifter wear, or shift lever wear that didn�t shift the under/over drive into complete engagement as you went through the crossover slot..
Clooney
Soldier Tom
01-05-2005 18:17:34
 720 d'sel does it too in reply to Clooney , 01-05-2005 16:15:03
My 720 d'sel will jump out of gear too, 3rd or 4th, while pulling. Same problem you suppose? Thanks
~Walk in peace~
Soldier Tom
Clooney
01-06-2005 02:58:30
 Re: 720 d'sel does it too in reply to Soldier Tom, 01-05-2005 18:17:34
Soldier Tom, see the post I wrote to Lyle a day or so ago (720 pops out of 4th gear only).. About the same problems hold true for yours.. [See link below]
Clooney
