HEAT CONTROL VALVE
STEVE CAN
08-11-2004 09:33:26
Would this be correct? When you open the heat control valve (turn it to hot position) it lets hot exhaust go to the intake manifold, to warm it. It looks to me that the exhaust goes from the control into the intake manifold and out the other side, of the intake manifold, back to the exaust. Am I correct in saying the hot exhaust does not mix with the intake air ,it just warms the intake manifold? This might seem like an unusual question. If this is correct, why would it be important to have the control set exactly on hot or cold? If it was set in between how would it effect the low idel problem? I don't quite undertand how it works. My manifol looks good except for the heat control. May have to purchase a new manifold (hope not)
Clooney
08-11-2004 11:48:51
 Re: HEAT CONTROL VALVE in reply to STEVE CAN, 08-11-2004 09:33:26
Steve you ask...
Quote: "When you open the heat control valve (turn it to hot position) it lets hot exhaust go to the intake manifold, to warm it. It looks to me that the exhaust goes from the control into the intake manifold and out the other side, of the intake manifold, back to the exhaust" .....
ANSW, that is correct with the manifold valve in the hot position it diverts hot exhaust gas around the front of the intake manifold & heats the manifold..
Quote: "Am I correct in saying the hot exhaust does not mix with the intake air ,it just warms the intake manifold" .....
ANSW, that is correct the hot exhaust is used for heating only & not exhaust gas recirculation..
Quote: "This might seem like an unusual question. If this is correct, why would it be important to have the control set exactly on hot or cold?��..
ANSW, if you look closely at that tapered valve & manifold passages you will see that if that valve isn�t on exactly hot or cold it blocks off part of the exhaust passage so that side cylinder can get it�s exhaust out..
Quote: �If it was set in between how would it effect the low idle problem��..
ANSW, in two ways,, if the exhaust can�t get out easily it won�t let the new fuel/air mixture in & if any exhaust stays in the cylinder it dilutes the new mixture with exhaust & that doesn�t allow the new mixture to ignite or burn easily.. Go out to your car or truck & manually hold the EGR valve open & you will see how it effects the idle on you engine [that�s presuming it runs long enough to tell how bad it runs]..
[email protected]
STEVE CAN
08-11-2004 12:03:03
 Re: HEAT CONTROL VALVE in reply to Clooney, 08-11-2004 11:48:51
THANKS CLooney, I finally understand why it makes a difference.
