Hey Clooney Re Your post on J D
STEVE CAN
08-10-2004 15:37:16
You gave me some suggestions on my "60" missing on one cyl. I had a fellow clean the carb. The tractor will run on both cyls except at a slow idle. I sprayed either on the intake manifold,it run better. So I removed the intake manifold to replace the gaskets. My question is about the manifold heat control. There is no indicater left where the control except short bolt (broken off) where the control should be. Now when I removed the intake manifold I noticed the manifold port that the air would go threw to warm the intake air was totaly plugged with rust and scale. Would I be correct in assuming the contol is set in the full cold position? Or shuld I remove the ex manifold to chek the control position?
Clooney
08-10-2004 17:07:03
 Re: Hey Clooney Re Your post on J D in reply to STEVE CAN, 08-10-2004 15:37:16
Steve, you ask..
Quote: "Now when I removed the intake manifold I noticed the manifold port that the air would go threw to warm the intake air was totally plugged with rust and scale. Would I be correct in assuming the control is set in the full cold position? Or should I remove the ex. manifold to check the control position?".....
Answ, you really can't assume that heat control valve is set COMPLETELY to cold but it obviously isn�t allowing much through.. You really should remove the manifold & either check it,, or at least use some heat & a big brass bar & drive that heat control valve down� Then remove the manifold & pull the heat control valve out & use a die-grinder or chisel to re-mark it for both HOT & COLD positions [or better yet buy a new valve]..If that valve isn�t set to EXACTLY �cold� or exactly �hot� it can cause low RPM runability problems..
With all that crud in the intake heat passage it should come off anyways as those manifolds are noted for corroding through on the bottom & that can severely effect low RPM & idle performance..
[email protected]
STEVE CAN
08-11-2004 09:33:26
 HEAT CONTROL VALVE in reply to Clooney , 08-10-2004 17:07:03
Would this be correct? When you open the heat control valve (turn it to hot position) it lets hot exhaust go to the intake manifold, to warm it. It looks to me that the exhaust goes from the control into the intake manifold and out the other side, of the intake manifold, back to the exaust. Am I correct in saying the hot exhaust does not mix with the intake air ,it just warms the intake manifold? This might seem like an unusual question. If this is correct, why would it be important to have the control set exactly on hot or cold? If it was set in between how would it effect the low idel problem? I don't quite undertand how it works. My manifol looks good except for the heat control. May have to purchase a new manifold (hope not)
Clooney
08-11-2004 11:48:51
 Re: HEAT CONTROL VALVE in reply to STEVE CAN, 08-11-2004 09:33:26
Steve you ask...
Quote: "When you open the heat control valve (turn it to hot position) it lets hot exhaust go to the intake manifold, to warm it. It looks to me that the exhaust goes from the control into the intake manifold and out the other side, of the intake manifold, back to the exhaust" .....
ANSW, that is correct with the manifold valve in the hot position it diverts hot exhaust gas around the front of the intake manifold & heats the manifold..
Quote: "Am I correct in saying the hot exhaust does not mix with the intake air ,it just warms the intake manifold" .....
ANSW, that is correct the hot exhaust is used for heating only & not exhaust gas recirculation..
Quote: "This might seem like an unusual question. If this is correct, why would it be important to have the control set exactly on hot or cold?��..
ANSW, if you look closely at that tapered valve & manifold passages you will see that if that valve isn�t on exactly hot or cold it blocks off part of the exhaust passage so that side cylinder can get it�s exhaust out..
Quote: �If it was set in between how would it effect the low idle problem��..
ANSW, in two ways,, if the exhaust can�t get out easily it won�t let the new fuel/air mixture in & if any exhaust stays in the cylinder it dilutes the new mixture with exhaust & that doesn�t allow the new mixture to ignite or burn easily.. Go out to your car or truck & manually hold the EGR valve open & you will see how it effects the idle on you engine [that�s presuming it runs long enough to tell how bad it runs]..
[email protected]
STEVE CAN
08-11-2004 12:03:03
 Re: HEAT CONTROL VALVE in reply to Clooney, 08-11-2004 11:48:51
THANKS CLooney, I finally understand why it makes a difference.
