Clooney on the pins?
Henry J
07-29-2004 18:38:36
Clooney
what do you use for the pin stock?
Thanx
Clooney
07-29-2004 18:55:02
 Re: Clooney on the pins? in reply to Henry J, 07-29-2004 18:38:36
Henry J, I have used both roll pins & drill bit shanks.. I haven't done any in a while but the last few I did about a year ago I drilled the holes the same size as the factory pins then used my die grinder & cut the straight ends off a few drill bits & used Loc-Tite 272 to hold them in the pin holes.. I liked the drill bits better than the roll pins..
[email protected]
Jeb2N
07-30-2004 03:39:16
 Re: Clooney on the pins? in reply to Clooney , 07-29-2004 18:55:02
Ok, i'm with you on the "bolt" portion of the fastener, but about that little wire part that the bolt hooks on to...the ones that I have basically looked like a % sign, consisting of a wire at a slight angle off of vertical and a spring/curly-cue at the top and bottom to give it some height off of the other piece of sheet metal. I think if I put in some hours and really concentrated, I could recreate that part out of some music wire that we ordered accidentally at work.
My other question is about how do you keep the Dzues fastener from just falling out of the hood when you go to remove the hood? The originals seemed to have some sort of eyelet or grommet that somehow held them in, but I fail to see how. How do you over come that problem, or do you just put them in a toolbox? I appreciate the help.
Jeb
Jason Z in MO
07-30-2004 07:02:58
 Re: Clooney on the pins? in reply to Jeb2N, 07-30-2004 03:39:16
The duez fastener you describe are used on aircraft. I used them on the wing baggage lockers I built into a set of wings I built. To keep the fastener from falling out I used a couple of hole punches to cut some rubber washers. I don't remember the exact diameters but roughly 3/4" and 3/16". I cut a 3/4" rubber disk out of an old inner tube then cut a 3/16" hole in the center of the disk. The center hole was slightly smaller than the shank of the fastener. (It steps to a smaller diameter closer to the head.
The rubber serves to keep the fastener in place and as an isolator between the two mating surfaces.
Clooney
07-30-2004 04:36:18
Jeb2N, you are probably talking about Duez fasteners.. Those are slightly different than the old Deere twist type hood fasteners [the Deere use a pin through the twist pin that twists into the seat].. If you are looking for the Duez type fasteners you might try the internet as those are still used for a lot of aircraft & racing applications.
[email protected]
