quarter turn hood latches
Jeb2N
07-29-2004 16:45:13
Ok, so on the older JD's that used the quarter-turn Dzues fittings...where do you find replacements for them? I know they're still made, but does anybody know of a good consolidated source that may offer them in different sizes? All the ones that i've been able to find had hex heads with a screwdriver slot in them, but i'm looking for a rounded, flush, button head type fitting with the flat slot in it. Any suggestions? Also, this is not going on a JD, but another tractor. JD is just the only brand that I knew of that definately used them so I figgured i'd ask here. Thanks!
Jeb
junkdigger
07-30-2004 13:42:16
 Re: quarter turn hood latches in reply to Jeb2N, 07-29-2004 16:45:13
The company I work for uses alot of these type of fasteners, or something similar. They buy from southco 1-610-459-4000, see quarter turn fastners on their webb site.
Link
Michael
Jeb2N
07-31-2004 06:57:02
 Re: quarter turn hood latches in reply to junkdigger, 07-30-2004 13:42:16
How exactly does the hardware fit together on the button side of things. As in, you have a hole in the hood, the oval head button fastener itself, and then there's like a grommet or something. How do you set the grommet to keep it from falling out and then how do you keep the button from falling out? Is there supposed to be a snap ring that fits in there somehow? I called several online places, but none of them seemed to be very knowledgeable about the Dzus fasteners and one place said that the grommet setter was over $200 and not a common item. (how can you install the grommets that you keep in stock if you don't have the tool?). Thanks.
Jeb
junkdigger
08-02-2004 03:14:00
 Re: quarter turn hood latches in reply to Jeb2N, 07-31-2004 06:57:02
Jeb,
The ones we use require no special tools to install. I'm not sure what the name of each part is, but I'll try to explain. The base which is what the fastener goes into is pressed into a hole. This hole must be the right size, as it is a press fit. I say pressed fit, but many times we will install them with a hammer.
You then drill a hole into the part being fastened (door, panel, etc.) just large enough for the fastener to go through. Before you put the fastener through the hole, you install a small spring. Then you install what you are calling a grommet (which is really only a small plastic cup). Next you place the fastener through the hole, and install, as you guessed a type snap ring. Now the fastener is trapped in the hole and will not come out. When you close, your door, hood, what ever, you push in the fastener, and give it a quarter turn to lock. At that point the spring on the fastener is compressed into the small plastic cup, out of sight, holding the hood closed.
To open you give the fastener a quarter turn to the left, and the little spring causes the fastener to pop forward, and release.
When these fasteners are closed they are very clean looking. All you see is the fastener head, which can be, Phillips, Common, Allen, or Thumb, and the plastic cup. As I said before the cup hides the spring, and is only 1/16 of an inch thick, usually black in color.
I'll try to take a picture of all the items, and send you.
Hope I am clear on how they work.
Michael
John R
07-30-2004 04:36:37
Common fasteners on airplanes. Go to your local airport and get chummy with their mechanic.
Clooney
07-29-2004 17:08:48
Jeb2N, Deere still carries them but you need a wheelbarrow full or money to buy more than a few.
Correct Connection was having someone try to tool up & start making them but I don't know if that ever got rolling or not [worth a call @ 814-9262764]
I don't know what parts you need but I usually make my own from 1/4" picnic table type round head bolts with a non threaded part under the head [takes a little grinding to remove the square shank under the head, a slot cut & a hole drilled for the pin.. If done correctly using the correct looking headed bolts they look just like original [except for the small stamped writing on the head]..
[email protected]
Henry J
07-29-2004 18:38:36
 Clooney on the pins? in reply to Clooney , 07-29-2004 17:08:48
Clooney
what do you use for the pin stock?
Thanx
Clooney
07-29-2004 18:55:02
 Re: Clooney on the pins? in reply to Henry J, 07-29-2004 18:38:36
Henry J, I have used both roll pins & drill bit shanks.. I haven't done any in a while but the last few I did about a year ago I drilled the holes the same size as the factory pins then used my die grinder & cut the straight ends off a few drill bits & used Loc-Tite 272 to hold them in the pin holes.. I liked the drill bits better than the roll pins..
[email protected]
Jeb2N
07-30-2004 03:39:16
 Re: Clooney on the pins? in reply to Clooney , 07-29-2004 18:55:02
Ok, i'm with you on the "bolt" portion of the fastener, but about that little wire part that the bolt hooks on to...the ones that I have basically looked like a % sign, consisting of a wire at a slight angle off of vertical and a spring/curly-cue at the top and bottom to give it some height off of the other piece of sheet metal. I think if I put in some hours and really concentrated, I could recreate that part out of some music wire that we ordered accidentally at work.
My other question is about how do you keep the Dzues fastener from just falling out of the hood when you go to remove the hood? The originals seemed to have some sort of eyelet or grommet that somehow held them in, but I fail to see how. How do you over come that problem, or do you just put them in a toolbox? I appreciate the help.
Jeb
Jason Z in MO
07-30-2004 07:02:58
 Re: Clooney on the pins? in reply to Jeb2N, 07-30-2004 03:39:16
The duez fastener you describe are used on aircraft. I used them on the wing baggage lockers I built into a set of wings I built. To keep the fastener from falling out I used a couple of hole punches to cut some rubber washers. I don't remember the exact diameters but roughly 3/4" and 3/16". I cut a 3/4" rubber disk out of an old inner tube then cut a 3/16" hole in the center of the disk. The center hole was slightly smaller than the shank of the fastener. (It steps to a smaller diameter closer to the head.
The rubber serves to keep the fastener in place and as an isolator between the two mating surfaces.
Clooney
07-30-2004 04:36:18
Jeb2N, you are probably talking about Duez fasteners.. Those are slightly different than the old Deere twist type hood fasteners [the Deere use a pin through the twist pin that twists into the seat].. If you are looking for the Duez type fasteners you might try the internet as those are still used for a lot of aircraft & racing applications.
[email protected]
