630 power steering problem
Jeff Oliver
05-24-2004 20:58:03
When you turn the steering to either side and then straighten it back out sometimes it will hang and stop turning. You can urn the wheel the other way just a little bit and it will come back around. Doesn't seem to make a difference which way you turn left or right. It acts like something is hanging or something, maybe a valve sticking then getting unstuck when the fluid changes direction? I am not familiar with how the sterring pump works so I don't really know. Any ideas??
Clooney
05-25-2004 04:11:51
 Re: 630 power steering problem in reply to Jeff Oliver, 05-24-2004 20:58:03
third party image
Jeff, see my post below to Buddy...[click on link]..
~Your problem is [well could be similar] depending on what version of the Deere power steering you have.. The 70 uses an earlier version of the Deere P/S than your 630.. If you have the correct vintage P/S in your tractor it doesn't use that pointed helix screw but instead uses a second pressed in pin.. Problem is: a lot of Deere 2-cylinder tractors have been converted to P/S & parts were used from anything handy.. The good news is most 30 series tractors came with factory P/S so you probably have the later steering..
~Your question..
Quote: �When you turn the steering to either side and then straighten it back out sometimes it will hang and stop turning. You can turn the wheel the other way just a little bit and it will come back around�>>>
_That is usually caused by the pin or pins #13B in the above picture being worn or the slots in the worm that those pins ride in being worn. It could also be caused by excess sleeve [#12B] end play or even the worm bearings being loose.. Loose worm bearings usually cause erratic steering & not a problem on return though.
~You can TRY a simple flow control adjustment & try increasing the flow control pressure a little to see if that will help the steering return to center before the pins catch in the worm slots.. Raising the flow control pressure is just a cover up & not an actual repair but in some cases can make it livable..
~On most steering complaints like yours I find the sleeve pins [13B] worn flat on one side & the cam slots worn with small pin sized divots in the sides of the worm slots.. Pulling the pins & turning them 90�, or better yet replacing the pins then using a small grinder & smoothing the slots out will usually get the steering working again. There is a lot of disassembly, re-adjustments & set-ups required to replace those pins & remove the worm..
~You really need to get the Deere Power Steering service manual before working on that steering system.. Those Deere P/S systems aren�t rocket science but can be difficult if you don�t FULLY understand what each part does & how it interacts with the other steering parts.. Some of the re-adjustments need to be made in the .0015� range so a good dial indicator will also be required..
Any questions on the above just post back or E-Mail..
[email protected]
Jeff
05-26-2004 10:28:51
 Re: Re: 630 power steering problem in reply to Clooney, 05-25-2004 04:11:51
Thanks forthe reply! I'll print this out and see what I can coe up with. I will probablytry turning the pressure up as we don't really use this tractor alot jut mainly showing and some hay loading. However when we get time I'll get the book and check the pump amd everything out.
