Carb. load adj. setting
JWS
05-24-2004 15:30:14
I will be installing a carb. on JD M after replacing gasket and cleaning. I removed load adj. needle but did not note setting. Any suggestions for initial setting? I have manual with instructions for setting while running. Thanks in advance.
M-Man
05-25-2004 18:23:17
 Re: Carb. load adj. setting in reply to JWS, 05-24-2004 15:30:14
jws;
Check this thread out. I had problems with my M carb a while ago and this thread helped me get it set to run like new. I found you don't want to set those M tractors too lean or they wont run good.
John T
05-24-2004 20:06:52
JWS, although you can initially start at closed down then maybe 1 1/2 to 2 1/2 turns out, you really need a good load to fine tune it. Its been my experience that if you have no load and set it by ear, you have to set it a tad on the rich (open) side so under a load she gets the fuel she needs. Still, I dont like to ever run any more over rich than I have to, cuz it can soot up and foul the plugs i.e. if you use her for light loads, you can set the power jet on the leaner side, but open it maybe 1/4 to 1/2 more for heavy use.
Good luck n God Bless ya
John T
Clooney
05-24-2004 18:26:33
JWS, the idle needle is set 2 turns out from seated but on the load needle I haven't seen any preliminary settings published anywhere.. You could probably use 2 to 2-1/2 turns out from seated to get it running then use the other load adjusting data you have..
[email protected]
Russ
05-24-2004 18:22:59
1 1/2 to 2 turns out from seated position is the general starting point for just about anything carbureted. You won't hurt anything even if you started out to the extreme of either side of these numbers (you'd get to experience what a very mal-adjusted carb acts like).
