Bearing parts Crankcase? Part 2
Rod M1
05-02-2004 21:14:14
Hi I found parts of a bearing cage and race in my crank case this weekend! The diameter is about 2-1/2 inches could that be a Governor bearing? How hard is it to check the Governor bearings? Thanks
Ralph - Wi
05-03-2004 17:44:04
 Re: Bearing parts Crankcase? Part 2 in reply to Rod M1, 05-02-2004 21:14:14
You have to remove the governor and fan shaft to check those bearings. If you had a proctologists omniscope you could remove the crankcase cover and sneak it up alongside of the timing gear. On the '46 there is a passage at the other end of the gov case as well. However it is almost certainly one of the gov bearings, although there is a chance it had been replaced earlier. If you do the gov, you might as well do the fanshaft bearings. Then with the gov and fan shaft out of the way it is only a few more bolts to take the head off and grind the valves, and with the head out of the way only a few more will ready the block for honing and new rings or reboring and new pistons. I have been down that road twice (different tractors) twice in the last three years. If you havn't done it before you probably don't want to tackle the gov and fan shaft on your own.
