Bearing Race crank case?
Rod M1
05-01-2004 22:40:21
Hi earlier to day I cleaned out the crude out of the crack case ( Model A ). There whose a lot of metal shavings and a few pieces of a Bearing cage and race in there! What could have this came from and would the tractor run with this bearing disintegrated like this? I think it mite have been a past repairer but not shire. How big of a job would it be to check this out with the top cover of? THANKS
Rod M1
05-02-2004 11:49:14
 Re: Bearing Race crank case? in reply to Rod M1, 05-01-2004 22:40:21
Thanks I found more pieces and it is definetly not a roller bearings its about 2-1/2 inches diameter is that a cranks bearing or something else?
G-MAN
05-02-2004 02:01:42
The only roller bearings in an "A" crankcase/engine are located on the ends of the camshaft or in the governor.
