John Deere Haybine Hydraulic go up won't go down
ken l
08-09-2003 08:36:16
I have a self propelled 830 john deere the cutter lifts but won'tcome down any ideas could really help.THank you
Brendan Casey
08-10-2003 20:08:05
 Re: John Deere Haybine Hydraulic go up won't go do in reply to ken l, 08-09-2003 08:36:16
This is not a specific suggestion to this problem, but rather an approach that may be helpful in this and other hydraulic troubleshooting situations:
Gary in TX
08-09-2003 22:25:52
Don't know for sure on your problem but I have heard those poppits can cause some problems. I just rebuilt the lift control valve on my JD 2280 windrower and it was a snap. It now lowers so smooth its a smooth as silk. It was dropping like a rock. The orings were hard as those same rocks as well. It was also missing the slow drop orifice as well. Its in there now and working so good. My thinking is your going to need to rebuild that lift valve and your problem should be solved, but no guarantees?????
Bob
08-09-2003 17:47:19
In the hydraulic control valve, there are some nylon poppets that have a metal pin sticking out of them, that do not allow the head to lower unless there is flow from the hydraulic pump (engine running). Something may be damaged in that area, or there may be foreign material stuck in the valve somewhere.
B.W.JOHNSON
08-09-2003 16:42:18
Would there be any quick connectors in any of the lines, if so the spring in the connector on the presure side will be week .Oil will pass through under presure but will not return. had this to happen to me on a disk , took a while to find it.
