Becareful...
John e.c.MI
11-01-2005 07:38:11
The problem with your hopper bin is that you will have a layer against the walls of the cone that will not move until the bin is nearly empty and you will have a hard time getting air to this part of the bin. ANother thing to remember is how are you testing the moisture on this corn? Corn through the combine is usually a couple of points wetter than a few hand shelled ears, your 18% corn may very well wind up being 20+. How about hauling your wet corn in and hauling dry corn home at the same time? You will avoid the storage charges and maybe you can get them to drop the load out as well. You really need corn down around 14% if you want to keep it around for a year.
