Probably not leakage
RickB
09-04-2005 13:42:59
An internal leak won't cause your symptom unless they are single acting cylinders with inadequate vents on the rod side of the piston. Otherwise the pressure will immediately equalize creating equal lift on both cylinders. The cause is a sprung boom or bent rod.
Will Weycker
09-04-2005 14:53:10
 Re: Probably not leakage in reply to RickB, 09-04-2005 13:42:59
Thanks Rick, How can i check to see if i have a sprung boom? Things look straight?
RickB
09-04-2005 16:37:02
 Re: Probably not leakage in reply to Will Weycker, 09-04-2005 14:53:10
Park on level concrete or other pavement. Measure from the center of each rear axle down to the ground; jack the low side to match the high side. Measure from the center of the pins attaching the bucket to the boom down to the ground. Also measure from the same pins to the center of the rear axle on each side or other FIXED reference point. Always measure from the rear axle, not the front. Always be sure the rear axle is level side to side.
will weycker
09-05-2005 06:43:31
 Re: Probably not leakage in reply to RickB, 09-04-2005 16:37:02
Great, Thanks Rick, You and others have been a big help on this.
