Hey Steve
txgrn
08-05-2005 04:41:30
I had an old Ford that I welded up as you mentioned. One of my tractors is Independent PTO and it snaps in place. You can't feather it like the hand lever on JD or like a live pto clutch pedal on a Ford.
Now I realize that the overrun clutch has nothing to do with what I'm talking about as it is used powering down, but.....
I worry that the force on the pto of getting the flywheel rolling will tear it up. I do idle down when I shift, but the operators manual says move it quickly forward to engage. It's basically a 2 position switch (lever).
Just seems like a lot of wear on the tractor. You can hear the clutches click as they are grabbing.
Your opinion?
Thanks,
Mark
Fighting suburbia in NC
08-09-2005 05:53:02
 Stop motor, engage PTO, start motor (maybe that wi in reply to txgrn, 08-05-2005 04:41:30
If the starter will take the torque it might be better to engage PTO with motor off then fire it up. We had a Leyland that was terrible about engaging the PTO if the motor was spinning. Never seemed to bother the starter when we started it with PTO engaged and 7' bushhog hanging off the back. Come to think of it, the 7' rotovator never bothered it either. YMMV
Steve from New Holland
08-06-2005 04:10:54
 Re: Hey Steve in reply to txgrn, 08-05-2005 04:41:30
Yes I do. What machine is this? A Baler? You speak of a flywheel. If it is a baler, I do NOT recomend eliminating the over-running clutch. As long as it is a mowing machine, then I am ok with it. Steve
