Loose knotter stack.
RickB
07-27-2005 16:55:13
If the billhook is still pinned to its pinion, excessive knotter stack endplay may have allowed the billhook pinion to jump time on its cam gear. Remove the capbolt and shims from the RH end of the knotter shaft, loosen the pinch bolt on the needle crank arm, and drive the crank arm to the right on the knotter shaft until you can put the billhook back in time. Then use the cap bolt with just the heavy washer less any shims to pull the crank arm and brake disc back onto the shaft, tightening the knotter stack until the knotters just rotate down by their own weight when unbolted and tipped up. Select shims just sufficient to allow the cap bolt to get tight without further tightening the stack. Tighten the pinch bolt on the crank arm. If the manual isn'tr much help, read it again. NH baler manuals are pretty good if you understand basic baler function.
