you are incorrect
Tim(nj)
06-10-2005 12:40:12
On smaller lighter tractors, a properly adjusted 3-point mounted plow will always pull easier than a trailer plow. The physics of the 3-point hitch will give traction to the rear wheels as the plow "sucks" in. The same tractor would need to have a bunch of weight slabbed onto the rear wheels to handle the same size trailer plow. I know from experience that I could pull a 3-point JD 416 3-14 with an MF65 gas utility at 45DB hp, but could not handle a JD 444 3-14 trailer plow, for lack of traction. Wheels would just slip trying to use it. The man who owned the 444 also had an MF65 gas, but his tractor was the row-crop version, that had bigger cast rear wheels, bigger tires that held more calcium, and some wheel weights added, so he could pull the trailer plow.
