Why I use disc cutter
Tx Jim
05-29-2005 04:18:41
Txgrn,I use a disc cutter because of three main reasons.Fire ant mound, gopher mounds and high humidity(lay hay flat with no need for windrow).Mine is as easy to hook up as a pulltype mo-co because it is mounted on a caddy.It will go over a terrace or depression as easily as mo-co.One can pull a disc cutter faster than mo-co but because of mounds,fields are tooooo rough.I cut mostly bermuda,some johnson grass,bahai or oats.Acres cut per set of blades depends on several things.Type of soil as sandy soil wears blades faster.Damper soil tends to wear blades faster.Changing blades is a lot faster than changing sickles or sections.Tx Jim
