But I only wnat a 3 bottom..will this work???
David McDan
04-20-2005 08:21:03
I want a 3-14 or 3-16 trailer type or 3 point type plow - not a 4 bottom...will this work or do I need a 4-14 to get the rear tires in the furrow?
RickB
04-20-2005 14:02:01
 Re: But I only wnat a 3 bottom..will this work??? in reply to David McDan, 04-20-2005 08:21:03
You can use a three bottom. The correct line of draft will be closer to the inside of the wheels than if it were a four bottom, but the plow is small enough relative to the tractor weight and power that it will make little if any difference. Go for it!
