Look anything like this one?
Indydirtfarmer
04-02-2005 15:35:05
third party image
This is a #416A, from the mid-50's until early 60's. If it looks simular, but a lot heavier, it MIGHT be a #810.
Jerry (AL)
04-02-2005 16:21:21
 Re: Look anything like this one? in reply to Indydirtfarmer, 04-02-2005 15:35:05
The lever is the same but the plow I have has a strait heavy channel all the full length. The wheel looks very similar but this wheel looks to be more rounded almost like a round steel tire split in half. The mounting hardware for the tail wheel looks the same as well as the way it hooks on the last bottom.
I have a digital camera. I will try to get a picture of it and then get someone to help me with how to post it here tomorrow.
You did a great job with that plow. Mine doesn't have coulters either. Mine is a trip though also. The one I have appears to be a heavier built plow.
Tim(nj)
04-02-2005 16:57:48
 Re: Look anything like this one? in reply to Jerry (AL), 04-02-2005 16:21:21
If you have a box beam that goes the length of the frame, it"s an F125.
Indydirtfarmer
04-02-2005 15:38:53
IF that's it, I have a spare tail wheel, and the brackets to mount it. The tailwheel takes a little "load" off of the landslides, making the plow pull a bit easier. Also, if that's it, I have the original manual for this plow, and I can copy it for you, so you can set up the tailwheel as it should be.
