3 Bottom JD Plow
Jerry (AL)
04-02-2005 15:03:08
I have a 3 bottom JD plow. I can't find any numbers on it anywhere. It has a lever on the front that appears to move the front left or right as you move the lever. I picked it up and originally took one of the bottoms off and it works Ok without a tail wheel. It was broken and a piece missing. Wheel is steel with yellow color inside. Number one, what is the purpose of the wheel? Every flat bottom I have ever used in my life seems to have been minus the tail wheel. I guess they get ripped off.
Does anyone out there know of a good source for old such wheels? I would like to get it back to original condition. JD no longer can supply the wheel. I carried it to a big local dealer and that was the word. I think this is a 3X16 if I remember correctly.
There is a stamping on the wheel D843A. The bearing side of the wheel is 18 inches. If there are any stampings on the plow, I have yet to find them.
Indydirtfarmer
04-03-2005 09:25:06
 Re: 3 Bottom JD Plow in reply to Jerry (AL), 04-02-2005 15:03:08
Looks like we've narrowed it down to the F125.... If you need/want an owners manual for that plow, I've got one. Let me know if you do. We can hook up via email.
Leroy
04-03-2005 06:23:16
Do you have the hub? That steel wheel can be replaced whith one for a rubber tire and the plow will work better as the steel like to hold onto mud if the ground is slightly wet. I think a standard 4 lug 4x12 trailer wheel will fit with just a standard 4:80x12" trailer tire, boat trailer size.
Indydirtfarmer
04-02-2005 15:35:05
 Look anything like this one? in reply to Jerry (AL), 04-02-2005 15:03:08
third party image
This is a #416A, from the mid-50's until early 60's. If it looks simular, but a lot heavier, it MIGHT be a #810.
Jerry (AL)
04-02-2005 16:21:21
 Re: Look anything like this one? in reply to Indydirtfarmer, 04-02-2005 15:35:05
The lever is the same but the plow I have has a strait heavy channel all the full length. The wheel looks very similar but this wheel looks to be more rounded almost like a round steel tire split in half. The mounting hardware for the tail wheel looks the same as well as the way it hooks on the last bottom.
I have a digital camera. I will try to get a picture of it and then get someone to help me with how to post it here tomorrow.
You did a great job with that plow. Mine doesn't have coulters either. Mine is a trip though also. The one I have appears to be a heavier built plow.
Tim(nj)
04-02-2005 16:57:48
 Re: Look anything like this one? in reply to Jerry (AL), 04-02-2005 16:21:21
If you have a box beam that goes the length of the frame, it"s an F125.
Indydirtfarmer
04-02-2005 15:38:53
IF that's it, I have a spare tail wheel, and the brackets to mount it. The tailwheel takes a little "load" off of the landslides, making the plow pull a bit easier. Also, if that's it, I have the original manual for this plow, and I can copy it for you, so you can set up the tailwheel as it should be.
